The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 137 guests, and 3 robots.
Forums50
Topics121,069
Posts970,530
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Exhaust manifold
ndkid275 #1376838 Sat Sep 12 2020 09:43 PM
Boltergeist
I've got a few of each stashed away- - - - -if I can locate them, I'll be glad to check it out. My "inventory control" system sort of resembles a pile of scrap iron, however!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
ndkid275 #1376839 Sat Sep 12 2020 09:49 PM
I appreciate it! I’ve got nothing but time since I haven’t even started the rebuild yet.
Thanks!
Chris
ndkid275 #1376844 Sat Sep 12 2020 10:26 PM
Jerry, if the I.D. is smaller wouldn't it slightly restrict the flow. Ed
Currently making 1954 3100 better than new
ndkid275 #1376862 Sun Sep 13 2020 01:27 AM
Doc,
I am asking about the exhaust manifold, not the intake manifold. Due to issues with the exhaust manifold, I am considering unbolting both my 216 and 261 and mating the 216 exhaust manifold with the 261 intake manifold.
Chris
Doc.Hall #1376864 Sun Sep 13 2020 01:40 AM
Boltergeist
That can actually help low end and midrange torque by increasing the velocity of the intake fuel and air gas column as it approaches the valve. If an engineer was deliberately trying to restrict high speed performance, he probably couldn't have done better than the Mickey Mouse port shape of a stovebolt cylinder head.
I don't think there's any real difference in 216 and 235 EXHAUST manifolds except the angle of the outlet.
ndkid275 #1376865 Sun Sep 13 2020 01:41 AM
I tried that with a 216 235 manifolds
The 4 bolts that hold the two together won’t line up
Got to use them as a set and they will interchange between the two engines
I’m running my 216 manifolds on my 235
I would suspect the 261 is like the 235 or even a third way different from the others
Let us know what you find out
-s
ndkid275 #1376866 Sun Sep 13 2020 01:50 AM
Boltergeist
OK- - - -finally somebody with some hands-on experience! Thanks! Is there enough of a difference in bolt spacing that one or the other of the parts couldn't be reamed to make the holes align? How about the mating flanges between the manifolds? Would a gasket seal?
ndkid275 #1376867 Sun Sep 13 2020 02:44 AM
If it’s just an angle difference for the exhaust, that helps me out. I hope I don’t have to go buy another intake/exhaust manifold! I will go back and measure the bolt pattern again. They seemed awfully close.
Chris
ndkid275 #1376870 Sun Sep 13 2020 03:21 AM
216’s dumped straight down up until 1948, then they angled back at the same angle as 235’s.
All this is moot as I stated in an earlier post, as the bolt pattern where the two bolt together is different, to be accurate the spacing of the two studs (not the carb studs) are different.
My Blog
ndkid275 #1376871 Sun Sep 13 2020 03:26 AM
Thanks Dave!
Page 2 of 2 1 2
Moderated by  Woogeroo
