The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (69Cuda, Ed Blouch, fonz8261, elhippie64, DavidBraley, 1 invisible), 193 guests, and 4 robots.
Forums50
Topics121,070
Posts970,583
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Exhaust manifold
#1376149 Sun Sep 06 2020 05:21 PM
Understanding that the intake manifold is a different, is the exhaust manifold the same from the 216 and 261? I found an exhaust manifold but there are issues with it.
Thoughts?
Chris
Re: Exhaust manifold
ndkid275 #1376155 Sun Sep 06 2020 06:08 PM
The 216 manifold has a wider spacing on the studs that hold the two together.
My Blog
ndkid275 #1376772 Sat Sep 12 2020 02:36 AM
Ok, I measured bolt patterns and unless I am missing something, the only difference I can find is the studs that hold the carb on. The rest appears to be the same.
ndkid275 #1376773 Sat Sep 12 2020 02:42 AM
You should see the bores are different. The later is larger diameter. I had to use the locating rings with the step in them to mate an early intake to the later block.
Dennis
40 Chevy 1/2 ton
ndkid275 #1376785 Sat Sep 12 2020 12:26 PM
The early 216/235 dipper engines have straight dump exhaust manifolds versus angled on the insert bearing 235/261.
ndkid275 #1376792 Sat Sep 12 2020 01:56 PM
Boltergeist
I'm pretty sure Chris is asking if a 216 exhaust manifold will bolt up to a 235/261 intake. I've got both items handy, and I'll see if it can be done in the next little while. Hands-on information is always better than guesswork, no matter how well-intentioned it might be.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
ndkid275 #1376810 Sat Sep 12 2020 04:17 PM
ace skiver
Yes, but, alignment-adapter rings are useful/necessary (for us mere mortals).
one style of rings [ebay.com]
MT might still make these rings? [jalopyjournal.com]
This thread might be useful?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
ndkid275 #1376823 Sat Sep 12 2020 07:20 PM
Boltergeist
The alignment rings are needed for adapting INTAKE manifolds. Chris is asking about the exhaust.
ndkid275 #1376831 Sat Sep 12 2020 08:11 PM
ace skiver
Thanks for the correction, Jerry
Tim
ndkid275 #1376836 Sat Sep 12 2020 09:40 PM
Yes, Jerry is correct. I am trying to figure out if a 216 exhaust manifold will bolt up to a 261 intake manifold.
Chris
Page 1 of 2 1 2
Moderated by  Woogeroo
