The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (Brad Allen, cmayna, 1958_Apache, 60ApacheC20, 3B, 1 invisible), 190 guests, and 4 robots.
Forums50
Topics120,968
Posts969,780
Members43,804
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Clutch wont disengage
#1376624 Thu Sep 10 2020 02:14 PM
DaddyD Offline OP
Help for 55 chevy 3100 it was fine when I parked the truck, I left it in neutral in the garage when I went back out to run it I started the truck no problem, I put it the clutch and tried to get it in gear and all it did was grind? I then turned off the truck put it in gear and attempted to start with my foot on the clutch and the truck moved forward with the clutch in and while it was turning over, kept working clutch to no avail
can anyone help with this problem? Thanks Daddy D
Re: Clutch wont disengage
DaddyD #1376642 Thu Sep 10 2020 04:35 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Clutch plate is stuck to the flywheel. Your procedure should free it up. If not you may have to crawl under and use a putty knife and hammer to free it. Once you get it free driving it will smooth everything back up. Drive it more often!
drive
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
DaddyD #1376665 Thu Sep 10 2020 10:27 PM
My '38 did the same thing this week. I haven't driven it in about 4 weeks. I started it in reverse and it popped loose. I have had to use the putty knife deal before.
Wayne
1938 1-Ton Farm Truck
Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. malmwayne@hotmail.com
DaddyD #1376721 Fri Sep 11 2020 03:56 PM
DaddyD Offline OP
Started in reverse and guess what? IT BROKE LOOSE
Thank you all for this easy solution, guess I will drive the old girl more.
Thanks All!!
DaddyD #1376743 Fri Sep 11 2020 09:36 PM
Hello DaddyD! I’m up here in Columbia,SC.
Moderated by  SWEET
