The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (Brad Allen, cmayna, 1958_Apache, 60ApacheC20, 3B, 1 invisible), 190 guests, and 4 robots.
Forums50
Topics120,968
Posts969,780
Members43,804
Most Online1,229
Jan 21st, 2020
Image Posting Policy
‘52 3100 Worn Rear Axle Shaft
#1376421 Tue Sep 08 2020 10:46 PM
Phak1 Online OP
AD Addict
I pulled my axles to replace the bearings and seals and discovered the area where the seal and bearings ride are corroded. Aside from the obvious (replacing the axles), are there any other options?
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: ‘52 3100 Worn Rear Axle Shaft
Phak1 #1376428 Tue Sep 08 2020 11:32 PM
Is that the actual bearing surface or does the bearing have an inner race? If do, a speedy sleeve would solve the seal problem.
Ed
Phak1 #1376430 Tue Sep 08 2020 11:39 PM
Or, have them machined to the next smaller inner bearing diameter.
Phak1 #1376450 Wed Sep 09 2020 02:01 AM
The roller bearings on a 1/2 ton run right on the axle. About the only fix other than replacing the axle is to machine them and put a sleeve on them, although that may not stand up to the load. Sleeves are generally for cleaning up seal surfaces. You could also get them machined,built up with metallizing (a welding type process), and re-machined to the correct diameter. That would probably be more expensive than replacing the axles.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Moderated by  SWEET
