The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (Cosmo, 6571, 46paneltruck, 37 GC, Bill Trotter, 1 invisible), 191 guests, and 3 robots.
Forums50
Topics121,042
Posts970,390
Members43,823
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Choke
#1376315 Mon Sep 07 2020 10:45 PM
Hi all, can’t figure out why my choke cable won’t open or close choke plate, this on a one barrel Rochester, I can open and close choke plate using my finger I’ve not had this carb apart. Pretty sure I have connected cable the right way.
Re: Choke
Dane Walton #1376333 Tue Sep 08 2020 01:34 AM
Chuckle... chuckle... this is atad bit funny, but all in all we alp started somewhere.. So that being said, we dont have enough info on the application etc. But if i had to guess, ill give you something to look at anyhow. Undo the choke cable from the carb. Does the cable move free? Does the choke plate move free? If either answer is , no, fix either or. If both answers are yes, you have it hooked up wrong. Open choke all the way in the carb, push choke cable in and hook it up to the carb. Pull it. Does the choke work? Let us know what you found. ohwell
Re: Choke
Dane Walton #1376336 Tue Sep 08 2020 01:59 AM
Dane,
What are you working with (yr, engine, carb, air cleaner). This is an easy mechanical system to fix. Just give us a little bit more info. Other things to consider in the meantime:
Tech is to depress throttle as you pull the cable. It allows the choke cable to miss the throttle linkage.
Cable could be crimped somewhere along the route.
In my case the eye that the cable passes through at the carb hits the underside of my air cleaner and does not allow the cable to move freely.
Maybe something else, but no doubt easy to fix.
HB
HB
1966 Chevrolet K-10
Flappy Fenders
In the Stovebolt Gallery [stovebolt.com]
More pictures on Photobucket [s160.photobucket.com]
1962 Chevrolet C10
1962 Suburban
Re: Choke
Dane Walton #1376349 Tue Sep 08 2020 06:59 AM
In addition to the possibility of a crimped cable and some sort of mechanical interference, check for corrosion anywhere along the length of the cable. It doesn't take much too rust inside the sheath for the wire to bind up... If you find this is the case, you can pull out the wire, coat it with light grease and re-insert. It should then operate freely.
Re: Choke
Dane Walton #1376350 Tue Sep 08 2020 08:19 AM
ace skiver
If tomctomc is correct, you might want to remove the cable-assembly and soak it in kerosene for a day or two?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Choke
Dane Walton #1376452 Wed Sep 09 2020 02:05 AM
I have had good luck with spraying the outer cable sheath with penetrating oil. It is nothing more than tightly wound spring steel and the penetrating oil goes right through it to the cable wire inside.
Moderated by  Woogeroo
