The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (chaz71, farmall100, 95Z28A4, 66flea, dirtball, 1 invisible), 184 guests, and 3 robots.
Forums50
Topics121,048
Posts970,425
Members43,831
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Having problems with My 216
Devilsix #1376117 Sun Sep 06 2020 10:02 AM
Adding choke strongly suggests a fuel issue .
Accelerator pump
Power valve
Jet or drilling Blockage
Missing ball bearing .
Devilsix #1376122 Sun Sep 06 2020 12:52 PM
Points?
kevinski 1954 GMC 9300 Welcome to the virtual Garage
KEVINSKI #1376133 Sun Sep 06 2020 03:08 PM
Accelerator pump
Power valve
I was also thinking fuel issue, But cant find any problems. But im gonna change carb and see if the problems Get better or Worse.
Originally Posted by KEVINSKI
Points?
I did not find the exact points on rockauto. So i have not Changed them yet
Devilsix #1376135 Sun Sep 06 2020 03:19 PM
Long shot, but if you have vacuum wipers, check to see if that system leaks. Take a propane torch and shoot some propane around the carb area, carb cleaner could do it to and see if there are leaks there. If you have a rochester B replace it with a carter YF, compression test should tell you something or eliminate a cause.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
My Webshots Album
Devilsix #1376197 Sun Sep 06 2020 11:56 PM
Just found out why my 216 is running like %^&@. The carb. insulator was cracked, so much so that it was sucking air. This was after rebuild, I did not notice the crack. It expanded after torquing down. Doc
Currently making 1954 3100 better than new
Devilsix #1376200 Mon Sep 07 2020 12:12 AM
Do you have a vacuum gauge? Find out what vacuum you are pulling at idle.
Do you get a decent spark from the spark plugs?
You need to do more testing.
Jumping down the rabbit hole of throwing parts at your truck to find the magic bullet is not the best way to go.
Devilsix #1376268 Mon Sep 07 2020 03:01 PM
That will do it! When you order one make sure you get the right size.
1946 1-ton Panel
My Webshots Album
Devilsix #1376270 Mon Sep 07 2020 03:05 PM
Stovebolt Photo Moderator
I would bet 52 Carl's last nickel that you have a vacuum hiccup somewhere........Joe
In this world there are givers and takers. The takers eat well, the givers sleep well......
A link to a few photos: https://photos.app.goo.gl/rwnBAvAWFckJTErs2
1947 - 3800 dually known as "Deadwrench"
Devilsix #1376316 Mon Sep 07 2020 11:07 PM
My last nickel just got spent on an unexpected 235 rebuild, but thank you for obligating my hard earn cash to perpetuate one of your vices, vicariously through me. I'm always here to help.
OP, Check to make sure that the small hole in the carburetor base lines up with the hole in the gasket.
Devilsix #1377542 Fri Sep 18 2020 05:31 PM
Could the probleme be My spark plugs?😅. I bought some of rockauto last year. I use motocraft sp476 resistor plugs. Heard now that i should never use resistor plugs on these engine. I just drove the car around town now with a little choke, and it runs perfect with choke As said earlier. Pulled the plugs and they all are pitch Black with soot.
Page 2 of 3 1 2 3
Moderated by  Woogeroo
