EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics122,165
Posts979,959
Members44,165
Most Online1,229 Jan 21st, 2020
 Need GMC 270 Piston Ring assistance
OP
Today, I thought I would button up aGMC 270. Installing .060 rings into pistons, and broke the bottom ring on a piston.
Oops!
So, I am not an expert at sizing rings, and I don’t want to buy a complete piston ring set for one broken ring.
Need your ideas? A standard 270 is 3.78125” diameter.
Is my math correct? .060 + 3.78125 =. 3.84125. Is there an engine with that bore size?
Would there be a source that sells a piston ring set for one piston or am I doomed for failure for the rest of my life, asking for forgiveness in the darkest of bars where men talk about these things and never let these things go, destined to lay out big bucks for one piston ring?
Thought? Assistance, advice?
Tom
 Re: Need GMC 270 Piston Ring assistance
My specs for a GMC 270 bore for .060 over is 3.836-3.838. Call Craig at Grant Rings. He was able to put together a set of standard rings for a 228 that I am building for my employer, and he may be able to help you out. 1-714-996-0050.
Joe
just retired and finally making headway on my project truck. 1940 GMC AC152.
OP
So much for Google and standard 270 search. You are correct. Thank you for the contact. Appreciate it. Tom
Call the manufacturer of the rings that you broke, they should be able to help with. I had Total-Seal rings help me out once, they were more then willing to make it right even though it was my fault.
OP
Thought I would post a follow-up to this post. Thanks to "gmc-is-me" I worked with Grant Rings and Craig Marder there who spent time with me on the phone and through emails and helped me size a correct ring for this 270. Craig was a big help and walked me through the three measurements he needed.
To put this in context, this effort was for just one ring - to the tune of $11.45 including shipping. I told him I would purchase a complete set for a 270 with one additional oil ring to help make it a little more cost effective for Grant. When we finished - he billed me for one ring - and sent the request to their shop who made me a perfect fit oil ring set.
This was not a money maker for Grant Rings - and I don't know how often they receive work for these old engines; but I suspect that this special order required his patience...that he graciously assisted with to help me get on my way (or, out of his way... LOL).
Just FYI. More than pleased with the service, the connection, the good work and the help.
Tom
Wow,a warm fuzzy in a cold, hard world.
OP
yes, a cold hard world - this old truck hobby brings out the best in the few. Have to give credit, where credit is due.
