The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (51sub, hardshell, DennisM, dands, archburycontrol, 3B), 160 guests, and 3 robots.
Forums50
Topics120,975
Posts969,812
Members43,809
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Installing fenders, inner fenders, radiator support. Help?
#1376236 Mon Sep 07 2020 03:53 AM
Dusty53 Offline OP
I'm almost certain ( if being 67 makes one's memory sharper ) that I read a post that someone had written about their experience and recommendations on the best procedure for reinstalling the fenders, inner fenders, radiator support and finally the radiator grill baffle and finally the hood and all the adjustment suggestions. I even thought that I had copied it and saved it. Well if I did, its lost. I have the shop manual and the factory assembly manual, but having someone put it into laymans terms would be great. Thanks for any help, it would be appreciated.
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: Installing fenders, inner fenders, radiator support. Help?
Dusty53 #1376240 Mon Sep 07 2020 05:31 AM
Here's one thread with some info from 52Carl.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Dusty53 #1376243 Mon Sep 07 2020 09:10 AM
Is this what you were looking for?
https://www.stovebolt.com/ubbthread...le-front-clip-1954-3600.html#Post1320840
1) Install the hood on the cowl, springs and all. It's easier to do it first before the fenders are in the way. Leave hood in the up position.
2) Mount the radiator support frame loosely onto the front crossmember. Start out with about 1/4" rubber shims under the feet.
3) Bolt the inner and outer fenders together OFF THE TRUCK.
4) Install the inner and outer fenders onto the truck AS A UNIT. It will go lots easier.
5) Install the large curved fender brackets between the radiator support and the outer edge of the fenders
6) Install the lower front splash shield. Connect the rods from it to the radiator support.
7) Install the grille.
8) Install the hood latch panel between the grille and the radiator support.
9) Install the radiator.
10) Install front bumper.
11) Install the front bumper filler panel.
1951 Chevy Panel Truck
MiraclePieCo #1376265 Mon Sep 07 2020 02:38 PM
Dusty53 Offline OP
Well, I thought I might be slipping and this proves it. Obviously I asked the same question in August 2019 and miraclepieco answered it! Thank you for helping me. Also, Thank you klhansen and of course 52Carl. Now I just need to get the hood repainted so I can start with it instead of the fenders. Oh, I created a folder on my PC and saved it all with a file name that cannot be confused. Thanks everyone.
Ronnie
Moderated by  HandyAndy, klhansen
