The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (D B Cooper), 63 guests, and 3 robots.
Forums60
Topics127,506
Posts1,032,015
Members45,793
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1954 235 Starter Questions
#1376055 Sat Sep 05 2020 10:23 PM
I see where it is said the difference between the 12 and 6 volt starters coincides with the flywheel tooth count. Why would I have 2 1954 trucks (apparently original with 6V everything) with the higher tooth count flywheels and smaller diameter gears on the starters that match with black tags not red?
Can I get the “12 volt” starter rebuilt to 6 v specifications so I don’t have to swap my clutch and flywheel? I know I can swap the truck to 12v. I just don’t feel like it!
Thanks.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
Re: 1954 235 Starter Questions
Dan Bowles #1376059 Sat Sep 05 2020 10:44 PM
Normally, a "black label" 6V starter will have an armature diameter of about 5/8", and it will be matched up with a 139 tooth flywheel. The 1955-up "red label" starter will have a shaft diameter close to 1/2", and the correct flywheel will have 168 teeth. BOTH starter drives have 9 teeth, but the tooth pitch will be slightly different. It might be possible to mix and match parts to get a 6V housing and field coils combined with a 12V armature and drive gear, but I have my doubts that it would crank at the proper speed with a 6V battery.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Dan Bowles #1376060 Sat Sep 05 2020 10:54 PM
I’ll have to run the number on the starter tag. Maybe someone previously mixed and matched.
Moderated by  Woogeroo
