The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (6571, 55shaker, drdoug, JeanBrive, GMJim, ASU), 223 guests, and 3 robots.
Forums60
Topics123,373
Posts995,639
Members44,648
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Power steering
#1376019 Sat Sep 05 2020 04:27 PM
Moderated
Has anyone changed to power steering on their 1954 3800 1 ton?
Thanks for any help
Re: Power steering
Dually54 #1376355 Tue Sep 08 2020 12:19 PM
Unrepentant VW Lover
Sorry about the late response .... could be that all the gang were out over the weekend ... smile Anyway, I have not. But I always ask the question: Why do you want to?
If you want to do it because you want to do it, or you have a medical/physical reason ... then by all means. But if you think you need to do it to get "better" steering .... In my own limited experience on three restorations, I have found that rebuilding the steering box, replacing the tie rod ends and king pins, and getting everything in adjustment (all things you'd want to do anyway) provides steering *almost* as easy and comfortable as power steering at a fraction of the effort, expense and fabrication. In my current truck (1949 3804), I routinely drive 60-65 mph with original steering (adjusted, naturally). I even run bias ply tires. Steering is solid. Even at a crawl in the parking lot, it isn't too bad. Not one finger, but certainly one hand.
But like I said, if you *want* to do it, then have at it. But you don't *have* to do it for better steering -- just rebuilding and adjusting what you already have will get you 85 to 90 percent of what power steering would do for you.
Food for thought.
"Of all tyrannies a tyranny sincerely exercised for the good of its victims may be the most oppressive."
— C. S. Lewis
'49 Chevrolet 3804
Re: Power steering
Dually54 #1376468 Wed Sep 09 2020 05:34 AM
Fox Offline
I second John. I run radials on my 51 GMC one ton and have a similar steering feel. However, on very grippy pavement at a stop is another sorry. Once inching along, it eases up a lot.
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- Rusty- the puzzle box lid for the C10.
1950 Chevrolet 1300- in progress to shiny.
1962 AMC Rambler American- my wife’s
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: Power steering
Dually54 #1376507 Wed Sep 09 2020 04:34 PM
I'm running 19.5 radials on my 51 chevy 1 ton with stock steering and it drives like a dream, If anything it may steer a little to easy. It took some getting use to when I first put them on.
Re: Power steering
Dually54 #1377014 Mon Sep 14 2020 05:18 PM
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Re: Power steering
Dually54 #1378026 Tue Sep 22 2020 05:12 AM
I have thought about adding PS to my '51 from time to time but where to put the PS pump has stymied me. I used the original generator mount for an A/C compressor and above that is the alternator. On the passenger side of the engine there just isn't anything to bolt a PS pump on to. No head bolts show outside the valve cover, no motor mount bosses on my engine. So I just have to lift weights between trips.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Re: Power steering
Dually54 #1378166 Wed Sep 23 2020 01:46 AM
Moderated
Thank you guys for the response.
Re: Power steering
1Ton_tommy #1378173 Wed Sep 23 2020 02:02 AM
Red dot, center of chest ...
I investigated this at one time. There's a way to get electric-assisted power steering, which eliminates the need for a power steering pump and all the associated problems with hydraulics and hydraulic oil. You'll have to research what's best/easiest for you to implement.
Electric Power Steering [ebay.com]https://www.ebay.com/motors/blog/convert-your-classic-to-electric-power-assist-steering/
Paul Schmehl CI 12
geek@stovebolt.com
Stovebolt Staff: Geek
1948 Chevy 3100 Five Window [stovebolt.com]
Moderated by  Grigg
