The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (Achipmunk, azcornman, 5 Window 9434, Charles in CA, Chevy's till I d, 1 invisible), 243 guests, and 3 robots.
Forums60
Topics123,374
Posts995,649
Members44,648
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Horn Bracket 1947 3100 with 235 engine.
#1375749 Thu Sep 03 2020 06:00 PM
Would anybody happen to have an extra bracket that is used to attach the horn to the engine. My horn is currently mounted on left fender in engine bay and I need this bracket to convert it to stock location. Don't want to make one. My truck is a 1947 3100 with 235 engine. Is there such a thing as a salvage yard for AD pickups? Thanks!
Last edited by Rusty Rod; Thu Sep 03 2020 06:10 PM. Reason: Please make a post in the swap meet area pertaining to selling or trading parts. thanks.
Re: Horn Bracket 1947 3100 with 235 engine.
bucktruck #1375755 Thu Sep 03 2020 06:12 PM
Moderator - The Electrical Bay and Rocky Mountain Bolters
Hello Buck, I moved your post to the swapmeet, as parts requests are not allowed in the discussion forums. Thanks.
Another quality post.
Real Trucks Rattle
Rusty Rod #1375769 Thu Sep 03 2020 07:41 PM
I'm sorry about that...it won't happen again.
bucktruck #1375851 Fri Sep 04 2020 01:27 AM
These brackets are now reproduced, eBay search 1937-52 Chevrolet horn bracket (they run about $25).
https://www.flickr.com/photos/advance-design_parts_co/50303395511/in/dateposted-public/
bucktruck #1375887 Fri Sep 04 2020 11:21 AM
Take a look here. Pretty cheap if you don't mind a repop.
https://www.classicparts.com/1937-1952-Horn-Mounting-Bracket-216/productinfo/53-371/
1949 5 Window 3100
Veteran of the USAF
https://zippi6.wixsite.com/adtruck
bucktruck #1375900 Fri Sep 04 2020 12:54 PM
It seems you can't use the suggested horn bracket that attaches to the manifold if you have the by pass oil filter system which also attaches to the manifold...which I have. I think there was a factory bracket but it is different from these. I may be wrong...I often am!
bucktruck #1375903 Fri Sep 04 2020 01:08 PM
“It seems you can't use the suggested horn bracket that attaches to the manifold if you have the by pass oil filter system which also attaches to the manifold.. “
Horn and oil filter on forward side of manifold? [ebay.com]
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
bucktruck #1375918 Fri Sep 04 2020 02:50 PM
That is the same set-up I run with the factory horn/bracket? Do you have a picture of your engine left side?
https://www.flickr.com/photos/advance-design_parts_co/8129178953/in/album-72157631867396207/
bucktruck #1375923 Fri Sep 04 2020 03:53 PM
It should fit fine. This is a 1950 with 235.
If you can not find the bracket let me know. I have an AD junk yard about 15 miles from me. He might have one. ( of you want original)
Todd
bucktruck #1376012 Sat Sep 05 2020 02:44 PM
Haunting the SBP since 2001
The offset horn bracket is not being reproduced & they don't turn up very often.
I have a nice one....PM me for more info.
Page 1 of 3 1 2 3
Moderated by  John Milliman
