The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (WE b OLD, MikeA777), 135 guests, and 3 robots.
Forums50
Topics120,972
Posts969,791
Members43,809
Most Online1,229
Jan 21st, 2020
Image Posting Policy
292 cross flow head mock up
#1374755 Tue Aug 25 2020 03:00 AM
mick53 Offline OP
I started mocking up my Ryan Falconer head for my 292. This is one head off his V12. The bore spacing is the same and additional head studs will need to be installed. Also a remote thermostat housing. I decided to have my main caps doweled thus removing the 800 hp barrier. I'm also stepping up to a 6-71 blower from my 4-71 and 2 650 dp carbs. My biggest concern is the push rod angle. I don't know how much that can be. The push rods are on the outside of the engine but they do clear the block. Leo Santucci has been helping me with this. He's a great guy and always to seems to have time for my craziness. He doesn't seem to think it's that big of a problem. I have seen BBC's with a lot of angle. If it works then I would build a frame and use the original cover design and probably pull a dry sump line out of it.
Re: 292 cross flow head mock up
mick53 #1374761 Tue Aug 25 2020 04:04 AM
I can't get past the pushrods being outside of the block!
An old farmer friend of mine would always say this about men who were way outside of the norm, "We need guys like him." That was all that he would say.
Some would assume that he was being derogatory. I do not think so. He is a very decent man. I would venture that he meant that as long as we have "guys like that", the rest of us can feel better about ourselves.
And for that, I thank you, sir. smile
mick53 #1374772 Tue Aug 25 2020 12:29 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
I can’t wait to see/hear a video of that magnificent engine running. How much longer do you figure?🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
mick53 #1374773 Tue Aug 25 2020 12:38 PM
Simply amazing! Want to see this video also. Keep up posted on the progress. Very interesting to say the least.
52Carl #1374870 Wed Aug 26 2020 02:30 AM
mick53 Offline OP
It's going to be a while. Hopefully next spring. Once I get the head figured out and the machine work done I have to take it to Hogan in North Carolina I think to have the intake designed and built. Then probably Wisconsin for the headers. I can't finish the dry sump until I decide if I'm pulling a line out of the lifters. I hope to start the chassis soon. Thank you.
mick53 #1374897 Wed Aug 26 2020 12:13 PM
Love it, looks like 200MPH just setting there.
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
mick53 #1374910 Wed Aug 26 2020 02:29 PM
Thanks for the update.
However: are the 3 openings between the intake ports water connections?
Was the cam supplied by Falconer, or is it a Chevrolet design?
mick53 #1374911 Wed Aug 26 2020 02:48 PM
Y
yar Offline
Great photos Mick. Thanks!
Is there a reason those heads do not use "D" shaped exhaust ports?: https://centuryperformance.freshdes...ock-chevy-what-is-a-d-port-cylinder-head
Will the push rods still be exposed when the assembly is complete?
Ray W
Ray
yar #1374971 Thu Aug 27 2020 02:27 AM
mick53 Offline OP
Ray W
They will be covered. I think I will have it plumbed to my dry sump pump.
panic #1374972 Thu Aug 27 2020 02:32 AM
mick53 Offline OP
His V12 is based on 2 inline 6's I believe. Chevy designed cam I think. I'm just getting into this. Yes the 3 ports are water outlets they will be plumbed into a remote thermostat housing. The bore spacing is the same as the 292. You would have to talk to Ryan about the design.
Moderated by  KCMongo
