The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 135 guests, and 3 robots.
Forums50
Topics121,069
Posts970,530
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Color of engine in ‘52 3100?
#1373412 Fri Aug 14 2020 11:57 PM
Phak1 Offline OP
AD Addict
I’m trying to decide what color I should paint my ‘59 235 in my ‘52 3100 and thought I would ask my fellow “Bolters” their opinions. It is now Chevy orange, which I am not really thrilled with, so I was thinking of gray, the original color of the 216. Were all engines in ‘52 gray or were there other colors? I’m Not trying to restore it to perfection but trying to keep it period correct, as much as possible.
What is your opinion?
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Color of engine in ‘52 3100?
Phak1 #1373415 Sat Aug 15 2020 12:21 AM
Quite a bit of discussion about colors... Read this recent thread.
https://www.stovebolt.com/ubbthread...ion-finishes-for-51-216.html#Post1369798
Personally, if I was to paint another 50's Chevy 6 I would choose Blue Oval blue. cool
Professional Novice
Phak1 #1373418 Sat Aug 15 2020 12:56 AM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Phak1 #1373420 Sat Aug 15 2020 01:09 AM
Phil, Both 216s and 235s in '52 were painted the same color, the dark-ish gray as discussed in this forum, called blue-gray in the Tech Article at this link: Jim Carter's Tech Article - Engine Paint Colors by Model Year [oldchevytrucks.com]. This article has the best compilation of colors I've seen, although I would be interested to know if others have a additional sources. EDIT: Tim beat me to it - looks like the same or similar list, in a different article. Cheers!
FWIW, the '59 235 would not have been Chevy orange from the factory... either gray (trucks) or blue (cars). I would favor the older 216/235 gray, FWIW.
If you are after the '52 look, consider a '53 or earlier valve cover, with the two central hold down studs. Easy swap using the earlier-style studs to replace two of the later engine rocker assembly hold-down bolts, as you probably know.
Doug
Phak1 #1373421 Sat Aug 15 2020 01:18 AM
ace skiver
Jim Carter makes reference to the original article written by Jim Henson (a copy of that original article is in my post above).
Tim
Phak1 #1373523 Sat Aug 15 2020 09:53 PM
No 235 / 261 should be orange.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
Phak1 #1373555 Sun Aug 16 2020 02:39 AM
Phak1 Offline OP
AD Addict
Being that the options for engine color in the 1/2 ton truck in 1952 was blue gray or blue gray, I think I stick with blue gray!
I didn’t realize that there had been such a discussion on the original color gray. I want to thank you all for your input.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1374539 Sun Aug 23 2020 12:21 PM
Phak1 Offline OP
AD Addict
Does the bell housing get painted the engine color or semi gloss black?
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1374543 Sun Aug 23 2020 12:32 PM
Phil,
Look at the engine gray color for Ford at any auto parts store...it is pretty close to one of the "blue gray" shades used by Chevrolet. Just don't tell any ardent Chevy guy as they may become unhinged. Most of the bellhousings I have seen were painted the same color as the engine.
Phak1 #1374552 Sun Aug 23 2020 01:28 PM
I sure believe I see the remains of black on the bellhousing of my 216.
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Page 1 of 2 1 2
Moderated by  Woogeroo
