The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (classicchevs, blueck), 140 guests, and 3 robots.
Forums50
Topics121,069
Posts970,530
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 5 of 5 1 2 3 4 5
Re: Horrible Sound from my 261
Wally / Montana #1373811 Mon Aug 17 2020 06:28 PM
Boltergeist
Sounds like our method on crappie and walleye in Tennessee- - - - -"Fillet and release"!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Wally / Montana #1373846 Mon Aug 17 2020 10:39 PM
The goal of the thread is to get back here on a Forest Service road in western Montana.
Pic from a few years ago.
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving but now on hiatus. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Wally / Montana #1374109 Thu Aug 20 2020 01:05 AM
Wally, I'm looking at the Clark Fork from the State park in Thompson Falls. The sun's just gone behind the mountain. It's hot and I've got no fishing gear 'cause we're returning from a funeral in SLC. Took the scenic route home right past your place I'll bet.
I took a 170 C.I. flathead Studebaker engine apart years ago for a ticking noise. Turned out to be a piston pin coming loose because the nut on the retainer pin worked loose. The pin was hitting the piston making the tic and the wrist pin had slid sideways and was about to begin wearing a groove in the cylinder wall. I drilled and lock-wired all the nuts. I've never had that happen on a Stovebolt but since you've got the pan off look carefully up in there.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Wally / Montana #1374122 Thu Aug 20 2020 01:57 AM
1-Ton, Yes, you overshot us. Are you in your '51 or another RV? Lower elevation up there = hotter.
I'll be looking up into the crank, etc as you suggest. Up there, though, is beyond my comfort level.
I'm embarrassed to say, my noise has been going on for a time. A video from 2018 has the noise as I took off. I always thought it was the water pump but no.
Wally / Montana #1374290 Fri Aug 21 2020 04:18 PM
We're pulling an old Avion 30 footer with a not quite as old Suburban, not the 51. We have pulled it with the 51 but it's hard to carry on a conversation at hiway speed. We're home now and the 51 is waiting patiently for its next trip to Seattle. Its transmission was getting noisy so a couple of weeks ago i pulled it and replaced all the bearings and stuff with a kit from Novak in Logan Utah. it is a good kit. I got a whole set of better gears from a guy on Stove Bolt (thank you very much) and it's now much quieter.
I finally listened to your recording of the noise. It's not coming from a flathead, Stude-six piston; that I can say. But you've investigated all the things others have suggested that might make a noise like that so I'm at a loss too. Try pulling the front main bearing cap as Hot Rod suggested. It won't cost anything except maybe a skinned knuckle. They are tight. The condition of the bearing might reveal a lot. The upper shell of the no. 1 main will sometimes wear more than the bottom. It did on mine, I think because the 2 pulley shivs are driving a big fan, alternator, and A/C compressor. I think on the later engines the mains are not pinned to the block like earlier ones, which makes inspecting the upper half about four hours easier.
Wally / Montana #1374350 Sat Aug 22 2020 12:25 AM
So this is like a soap opera. Has Cooter hit that dry spot with oil yet??
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Wally / Montana #1374395 Sat Aug 22 2020 12:59 PM
Lolol yea it does. I was following for a bit, but the conversation went to all kind of boring areas and 5 pages later. All i would like to know is, did the mysterious noise ever get discovered??
Moderated by  Woogeroo
