The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
Since we put up promos last two weeks, we have had a bunch of activity in
The Side Lot.
See what's happening with a Stovebolt Collective near you
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: too many to list!
THE SIDE LOT.
Go see!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (D B Cooper, 37 GC, 32vsnake, Gdads51, DadsFirstPickup, 2ManyTrucks), 108 guests, and 4 robots.
Forums60
Topics129,236
Posts1,048,088
Members46,231
Most Online1,229
Jan 21st, 2020
#1373746 Mon Aug 17 2020 11:14 AM
AwDang Offline OP
Is there a more modern front hub with 9/16” studs that adapts to the 49 spindle?
Bonus if it increases track width too.
Pat
1940’s tech was great in the 40’s
What is the problem with the old hubs?
It would probably be possible to adapt a later model spindle to the existing kingpin mounts. We used to install a 3/4 ton Ford rear axle load tube to the right front hub and run a "wide 5" front wheel and brake on the dirt track cars. A good machinist and welder could probably do something similar with a 3600 steering knuckle assembly. I'd probably cut off the existing spindle, bore a hole in the steering knuckle, and fabricate an appropriate-sized spindle from bar stock and press and weld it into place. Another method would be to turn the existing spindle down to a straight contour and press a fabricated spindle over it, then make a weld back at the steering knuckle. Difficult, but not impossible!
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
AwDang Offline OP
It would be easier just to turn some custom hubs.....
Pat
3B Offline
Hy AwDang, Is your truck currently the single wheel version? If it is the single wheel version, you could swap dual wheel hubs onto the front, that would increase your track dramatically, maybe even too much.
3B #1373853 Mon Aug 17 2020 11:27 PM
AwDang Offline OP
Hum....gotta look into that. 3800 dually front hubs?
Pat
Moderated by  SWEET
