The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (MikeStone1953, Mickey3100, Fox, 46paneltruck, 3B, dands), 190 guests, and 3 robots.
Forums50
Topics121,036
Posts970,295
Members43,817
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Hot Tub Question?
#1373752 Mon Aug 17 2020 01:34 PM
Tommy Offline OP
Many years ago I bought a Big hot tub and have used it ,and enjoyed it. How ever it is now time to dispose of it. The base is rotten ( termites like hot tubs also.). The trash collectors said it is to big for the trash truck with the big claw to pick up, but if I cut it up in little pieces I can dispose of it at the dump. So how do I cut it up? I have a reciprocating saw, but don't know what kind of blade to use? I believe the tub is made of fiberglass, but may be some other composite material. Any suggestions ?
Tommy
59 apache 1/2t
261 short stepside
Re: Hot Tub Question?
Tommy #1373754 Mon Aug 17 2020 01:54 PM
I would think it is fiberglass and a wood blade should work well cutting it up.
Warning
Do it away from the house. Cover all your body with heavy clothes, including your neck, hair and goggles for your eyes.
A good N-95 face mask is also a must.
If you can get a fan blowing on your back as you cut will also help.
As soon as you are done, all the clothes you had on go into the washer, just those clothes by themselves.
You get into the shower and scrub down good.
You will still probably itch for a few days despite taking these precautions.
Don
Edit: If you can keep it wet, that will also help. Use a GFI if you are using 110 V power.
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Tommy #1373760 Mon Aug 17 2020 02:20 PM
Tommy Offline OP
Don, Thanks for the reply, I've worked with fiberglass before, Insulated houses in the early 70's and built a 24 ft. shrimp boat. So I am familiar with the Itch, and all of the cover up info. I have a 36 inch box fan that I was going to use behind me. Just wasn't sure about the kind of blade, couldn't find anything at the big box stores that was for fiberglass.
Tommy
59 apache 1/2t
261 short stepside
Tommy #1373766 Mon Aug 17 2020 02:56 PM
thumbs_up. What Don said.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Tommy #1373774 Mon Aug 17 2020 03:26 PM
I worked with composites for 30 years. Fiberglass isn't difficult to cut. Like Don said any blade that will cut wood should do just fine. Carbon fiber on the other hand will eat up normal cutting tools like a cop in a donut shop.
Tommy #1373775 Mon Aug 17 2020 03:33 PM
Boltergeist
Another approach would be to use a thin cutoff wheel in a small angle grinder. You'll probably make less, but somewhat finer debris that way due to the thinner kerf the blade makes. I use my angle grinder on a lot of non-ferrous stuff, and it does a pretty good job. Just be sure to make straight cuts only- - - -those thin cutoff wheels don't like any side pressure at all and when one shatters, it's impressive!
Quick, and extremely dirty- - - -use a chain saw!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Tommy #1373777 Mon Aug 17 2020 04:24 PM
"Like a Cop in a Donut shop"?
Wait till Martin sees this!
eeeek
"The Flag Pole"
'50 2-ton flatbed
Tommy #1373780 Mon Aug 17 2020 04:41 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Tommy #1373786 Mon Aug 17 2020 04:51 PM
Workshop Owner
Put it on Craigslist for free. I have seen much worse items listed. If no interest in a week or two, do like Don said.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
Tommy #1373823 Mon Aug 17 2020 08:43 PM
As long as it is fiberglass you'll be ok to cut it as per above. Personally I'd choose the chain saw because you'll be finished tout de suite. If on the other hand it was made from cultured marble (which is possible but very uncommon) it will be something you'd be better off paying somebody to haul away. Probably 99% of those around here are just plain old fiberglass. 4 years ago we had to remove a cultured marble tub. First we cut it into 6 pieces using a cutoff wheel like Jerry said. The lightest of those felt like it weighed about 120 pounds and I'm certain the heaviest easily weighed over 200 pounds. I took it all out to the curb for pickup but by the 6th piece it was Miller time for me.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Page 1 of 2 1 2
Moderated by  Bouncer, Justhorsenround, Tiny
