The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (Dobey334, Justhorsenround, Adamg, J Lucas, 3 invisible), 149 guests, and 3 robots.
Forums60
Topics123,946
Posts1,000,283
Members44,788
Most Online1,229
Jan 21st, 2020
Image Posting Policy
49 3600 alternate front hubs
#1373746 Mon Aug 17 2020 11:14 AM
AwDang Offline OP
Is there a more modern front hub with 9/16” studs that adapts to the 49 spindle?
Bonus if it increases track width too.
Pat
1940’s tech was great in the 40’s
Re: 49 3600 alternate front hubs
AwDang #1373801 Mon Aug 17 2020 05:46 PM
What is the problem with the old hubs?
1951 1 Ton Completed
AwDang #1373803 Mon Aug 17 2020 05:52 PM
It would probably be possible to adapt a later model spindle to the existing kingpin mounts. We used to install a 3/4 ton Ford rear axle load tube to the right front hub and run a "wide 5" front wheel and brake on the dirt track cars. A good machinist and welder could probably do something similar with a 3600 steering knuckle assembly. I'd probably cut off the existing spindle, bore a hole in the steering knuckle, and fabricate an appropriate-sized spindle from bar stock and press and weld it into place. Another method would be to turn the existing spindle down to a straight contour and press a fabricated spindle over it, then make a weld back at the steering knuckle. Difficult, but not impossible!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #1373831 Mon Aug 17 2020 09:25 PM
AwDang Offline OP
It would be easier just to turn some custom hubs.....
Pat
AwDang #1373851 Mon Aug 17 2020 11:18 PM
3B Offline
Hy AwDang, Is your truck currently the single wheel version? If it is the single wheel version, you could swap dual wheel hubs onto the front, that would increase your track dramatically, maybe even too much.
3B #1373853 Mon Aug 17 2020 11:27 PM
AwDang Offline OP
Hum....gotta look into that. 3800 dually front hubs?
Pat
Moderated by  SWEET
