0 members (),
167
robots. |
Key:
Admin,
Mod
Forums59
Topics128,305
Posts1,053,934
Members46,604
Most Online1,229 Jan 21st, 2020
OP
Is there a more modern front hub with 9/16” studs that adapts to the 49 spindle? Bonus if it increases track width too.
Pat 1940’s tech was great in the 40’s
What is the problem with the old hubs?
It would probably be possible to adapt a later model spindle to the existing kingpin mounts. We used to install a 3/4 ton Ford rear axle load tube to the right front hub and run a "wide 5" front wheel and brake on the dirt track cars. A good machinist and welder could probably do something similar with a 3600 steering knuckle assembly. I'd probably cut off the existing spindle, bore a hole in the steering knuckle, and fabricate an appropriate-sized spindle from bar stock and press and weld it into place. Another method would be to turn the existing spindle down to a straight contour and press a fabricated spindle over it, then make a weld back at the steering knuckle. Difficult, but not impossible! Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
OP
It would probably be possible to adapt a later model spindle to the existing kingpin mounts. We used to install a 3/4 ton Ford rear axle load tube to the right front hub and run a "wide 5" front wheel and brake on the dirt track cars. A good machinist and welder could probably do something similar with a 3600 steering knuckle assembly. I'd probably cut off the existing spindle, bore a hole in the steering knuckle, and fabricate an appropriate-sized spindle from bar stock and press and weld it into place. Another method would be to turn the existing spindle down to a straight contour and press a fabricated spindle over it, then make a weld back at the steering knuckle. Difficult, but not impossible! Jerry It would be easier just to turn some custom hubs.....
Hy AwDang, Is your truck currently the single wheel version? If it is the single wheel version, you could swap dual wheel hubs onto the front, that would increase your track dramatically, maybe even too much.
OP
Hy AwDang, Is your truck currently the single wheel version? If it is the single wheel version, you could swap dual wheel hubs onto the front, that would increase your track dramatically, maybe even too much. Hum....gotta look into that. 3800 dually front hubs?
