The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (MT53, Fox, KEVINSKI, homer52), 189 guests, and 3 robots.
Forums50
Topics121,036
Posts970,296
Members43,817
Most Online1,229
Jan 21st, 2020
Image Posting Policy
New Kuebler 12v engine hours operated counter
#1373143 Wed Aug 12 2020 10:55 PM
Jon G Offline OP
While this meter is generally thought of more in the marine, aviation, construction equipment fields, I (and others) like to keep count of the number of hours on auto engines, too...especially on older vehicles. Hours operated plus mileage driven provides average speed, travel patterns...several things if you're of a mind to use the data. This high quality German made 12v hour meter isn't re-settable and can be used to monitor hours used on nearly anything with a bit of imagination. This is a model HK07 (10 91 date). It has a positive lead, a negative lead and the yellow lead disables the counting process (if desired). One very positive aspect of this meter is that it (unlike the Chinese meters) does not require a battery and can't fail from lack of battery power. Plus if power goes out, the numbers are frozen and the data isn't lost. This 7 digit counter registers up to 99,999 hours and there are two red digits to the right which measure minutes. If desired it can be illuminated with a small bulb or a white LED if panel mounted. $25 shipped to any USA address. Info, dimensions, etc here:
https://www.kuebler.com/en/products...ters/product-finder/product-details/HK07
If questions, please ask.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: New Kuebler 12v engine hours operated counter
Jon G #1373620 Sun Aug 16 2020 05:47 PM
Workshop Owner
Sold, Jon I'll take. I will be the only kid on the block that has one. grin
PM sent.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
Jon G #1373670 Sun Aug 16 2020 10:30 PM
Jon G Offline OP
This one is gone...thanks.
Jon
Moderated by  Tiny
