The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (Mickey3100, blueck), 175 guests, and 3 robots.
Forums50
Topics121,036
Posts970,299
Members43,817
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Adjusting brakes on 46 Chevy 1/2 ton
#1373587 Sun Aug 16 2020 12:53 PM
fred c Offline OP
46 Chevy 1/2 Ton 1929 Model A Phaeton
Can someone tell me what is the correct way to adjust the brakes on my 46 Chevy 1/2 ton. The brakes are stock. There are 2 adjusters for each wheel. One for each brake shoe. I'm guessing that both adjusters should be backed off so the wheel spins freely. Then I should adjust one shoe to the point where the wheel will not turn. Then back off on that adjuster until the wheel spins with slight drag. Then adjust the second adjuster until the wheel can not be turn and then back off on it until the wheel spins with slight drag. This makes sense to me but is this correct?
Re: Adjusting brakes on 46 Chevy 1/2 ton
fred c #1373591 Sun Aug 16 2020 01:57 PM
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
fred c #1373592 Sun Aug 16 2020 02:09 PM
fred c Offline OP
thanks HandyAndy. Do you know if the adjustment procedure I explained is correct? Or is there a better way.
fred c #1373594 Sun Aug 16 2020 02:58 PM
I'm sure your procedure would get you there.....
I don't adjust them so tight that the wheel won't spin. While adjusting, I spin the wheel to the front on the front adjuster and toward the rear on the rear adjuster for each wheel. I adjust for a 'good' amount of drag and then loosen for a slight drag. Be sure your parking brake is adjusted correctly too. Click on the link in my previous post for the shop manual instructions.
Andy
fred c #1373603 Sun Aug 16 2020 03:37 PM
fred c Offline OP
Got it. Thanks HandyAndy
Moderated by  SWEET
