The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
23 members (Donf, 3800GUY, Brad Allen, DennisM, Bill Marlow, 3 invisible), 152 guests, and 3 robots.
Forums58
Topics122,634
Posts989,433
Members44,504
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Any home electrician out there????
#1373281 Fri Aug 14 2020 09:35 AM
Last night as I got ready for bed I turned on the hall light for that end of the house. No lights. I check the circuit breaker it seems to be ok. The strange thing is half of the master bedroom has no power but the bath and some of the wall sockets in the north part of the area do. 2 other bedrooms and the hall ceiling light do not. I check the breaker seems ok it does not flop around. Any helpful suggestions would be welcome. The house built in 1971 and it was built by the same contractor that built about 400 or more in the area. Not the best quality.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Re: Any home electrician out there????
WE b OLD #1373289 Fri Aug 14 2020 12:45 PM
back yard wrench turner
sounds like a GFI has tripped.
Wayne
1938 1-Ton Farm Truck
In the Stovebolt Gallery [stovebolt.com]
Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. malmwayne@hotmail.com
WE b OLD #1373293 Fri Aug 14 2020 01:22 PM
That happened to me years ago.
One leg of the 220 buried underground to the house shorted out.
Your ac probably also does not work.
Power company came out and repaired the same day at no charge. Made a mess in the yard though.
They are responsible to the meter, the rest is yours in your house.
Call them right now and they should have someone there in just a few hours or less.
Tell them your age and they will make it an emergency call.
Let us know what it turns out to be.
Don
"The Flag Pole"
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
WE b OLD #1373300 Fri Aug 14 2020 02:14 PM
We lost power to the front bathroom a month or so back. I called the electrician because none of the breakers had tripped. Before he got here I discovered a GFI receptical behind some books that had tripped and the rest were daisy chained off of it.
WE b OLD #1373316 Fri Aug 14 2020 03:28 PM
I would like to echo what tiny said. Check your GFI and see if that cures the problem. The last place I lived had a seldom used restroom. It also had a couple of exterior receptacles. One day the outdoor receptacles just stopped working. No GFI, and no tripped breakers. I puzzled over this for a while, and by accident I needed to use the outlet in the restroom. No juice. I reset the GFI and the restroom came back to life, and you guessed it so did the outdoor receptacles.
WE b OLD #1373328 Fri Aug 14 2020 04:26 PM
He was here already. He check the GfI, only one in the house pronounced it ok and it is the bathroom that all the lights and fan works . As far the electric company tells me in letters wanting me to buy insurance for anything outide the house, because they say it is on me. He is coming back Monday. Strange it is the 3 bedrooms and hall way in that end of the house. One recepticle in the bedroom is on with north part of the house. BTW a/c is fine. ohwell
2017 Buick Encore
Pix on Photobucket
WE b OLD #1373341 Fri Aug 14 2020 06:09 PM
Here they're responsible for everything their side of the meter.
WE b OLD #1373363 Fri Aug 14 2020 08:49 PM
Where I'm at , lights in the ceiling are wired separate from outlets. If you blow a plug, the lights stay on, I guess would be the reasoning. Since the AC takes 2 legs and works, I would say you lost a wire at an outlet and not one of your legs. Everything downstream from that lost wire would be dead. Has happened to me more than once in my life. I would head to a receptacle that is used often. That minor movement from plugging and unplugging could've made one of your wires pop off if the original electrician didn't tighten it down like he was supposed to.
WE b OLD #1373365 Fri Aug 14 2020 08:52 PM
BTW, this is assuming you have a HVAC, not a window AC unit. If this is the case, check to see if one of your 220v items works. Compressor, dryer, etc. If a 220v item doesn't work, you've lost a leg.
WE b OLD #1373383 Fri Aug 14 2020 09:51 PM
If your house was built in 1971, it may have aluminum wiring, or at least a hybrid copper/aluminum. Aluminum wires are prone to separating at the wire connectors. If so, they can cause arcing and/or overheating of wires. Just something else to check.
don
Page 1 of 2 1 2
Moderated by  Bouncer, Justhorsenround
