The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (clarsen3100, Chev4t6, dougs, DougH6100, buoymaker, 1 invisible), 210 guests, and 3 robots.
Forums50
Topics120,917
Posts969,284
Members43,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
New tie rod ends
#1372854 Mon Aug 10 2020 10:12 PM
49shep Offline OP
Does anyone happen to know how the tie rod end should be assembled? Does it go tie rod end, metal cup, rubber washer? Or does the rubber washer go between the tie rod end and the metal cup? I don't recall where I got these ends from and I can't find any pictures online of this style. Also, does it matter which end goes left and which goes right? Or as long as I thread them on to the correct end of the long tie rod, it shouldn't matter? Attached a picture. Thank you
1950 (I think) Chevy 3100
Re: New tie rod ends
49shep #1372862 Mon Aug 10 2020 10:50 PM
ace skiver
What year and size Chevrolet truck?
Original-equipment-style tie rod ends?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
49shep #1372867 Mon Aug 10 2020 11:16 PM
49shep Offline OP
Hi Tim, 1950 Chevy 1/2 ton. The tie rods are replacement style. I hammered out the old balls from the steering arm. I took a better pic of just the tie rod end if that helps.
49shep #1372881 Tue Aug 11 2020 12:48 AM
ace skiver
I have never used that style set.
However, your photos and year-information should get you some helpful responses.
Tim
49shep #1372882 Tue Aug 11 2020 12:59 AM
The rubber is to seal the ball from road debris and water , then the metal washer holds it in place , you have it wrong in your first pic .
Normal fitment is right hand thread on the right side , left hand thread on the left side . Helps avoid confusion smile
49shep #1372884 Tue Aug 11 2020 01:12 AM
49shep Offline OP
Much appreciated! Thank you.
Moderated by  SWEET
