The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (Comediann, Pretzer46, 1 invisible), 172 guests, and 3 robots.
Forums50
Topics121,069
Posts970,532
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
dash parts
#1372379 Fri Aug 07 2020 02:01 AM
1937 gmc truck looking for dash brackets and what ever goes between the dash and fire wall that holds the front windshield regulator.
Re: dash parts
robert b #1372390 Fri Aug 07 2020 02:39 AM
I believe the windshield regulator is held to the top of the dash by two bolts; no brackets or other pieces needed. The problem is it is very difficult to mount or remove the regulator without removing the dash first. On the Art Deco series (41-46) the regulator is relatively easy to access from under the dash but nearly impossible in the 37. Good luck,
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Re: dash parts
robert b #1372469 Fri Aug 07 2020 05:43 PM
If the GMC regulator and mounting is the same as Chevy the attached photo will be what to expect. I found it impossible to access the regulator without removing the dash. The two screws used to secure the regulator to the cab frame could not be reached otherwise. Removing the dash is also a hassle since it was apparently factory installed after the regulator. I was forced to make some small cuts at one of the bottom corners in order to get enough clearance.
Re: dash parts
robert b #1372511 Sat Aug 08 2020 12:28 AM
ok on mine I don't have the strip that looks like it bolts to the cab. on mine the cab has holes so now it's getting better for me to understand what's going on thank you for the help
Re: dash parts
robert b #1372637 Sun Aug 09 2020 02:25 PM
Robert,
The strip is called the "tongue". It bolts to the window frame, not the cab. Jim Carter (and perhaps other vendors) have reproductions of the strip for sale.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Re: dash parts
robert b #1372710 Mon Aug 10 2020 12:40 AM
I've got the regulator I need the steel brace if that's what you call it
Re: dash parts
robert b #1372744 Mon Aug 10 2020 05:02 AM
Are you asking about the part shown in 46Sparky's photo, shiny with square holes? If not, what part do you mean?
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Re: dash parts
robert b #1372869 Mon Aug 10 2020 11:19 PM
cover the shiny square holes and the regulator. it's the rusty color metal brace that the regulator bolts to in the picture
Re: dash parts
robert b #1372890 Tue Aug 11 2020 01:30 AM
I don't understand your first sentence. The regulator is bolted to the cab structure, not a separate brace. That area is covered by the dash when the dash is attached.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Re: dash parts
robert b #1373031 Wed Aug 12 2020 12:11 AM
the truck I got does not have the rusty color part. on the cab center there is a grove cut for the regulator and 3 hole on left side and 3 holes on the right side it's like there should be that part in the picture that goes there.
Moderated by  Tiny
