The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (chaz71, RoseB, 5 Window 9434), 158 guests, and 3 robots.
Forums50
Topics121,069
Posts970,532
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Rattle Can woes
klhansen #1371992 Mon Aug 03 2020 10:34 PM
unless you have modern "spray in any position" cans, which do not need this upside down cleaning, because you can't even if you wanted to, just sprays paint upside down.
i always remove the tip from the spray can as soon as it's empty, blast it with the compressor, throw it into your spray can tips bin, next time a tip is clogged beyond cleaning you will find a fresh ready to go tip in your spare can tips bin, after 20 years you will have a tip to fit all brands and types of cans.
-s
Re: Rattle Can woes
klhansen #1372000 Tue Aug 04 2020 12:36 AM
Yep. Theres that too. I forgot about the any position cans. I usually realize it when paint keeps coming out, upside down. dang
Re: Rattle Can woes
klhansen #1372001 Tue Aug 04 2020 12:45 AM
General Purpose
I have not had one clogged paint can in 10 years. Turn upside down, spray for the count of 1,2,3.........IMMEDIATELY wipe nozzle hole with a rag. Must wipe good on nozzle hole and surrounding. Don't tilt nozzle while wiping or it will spray again. Can't wait to do this, must be done right away. Even during coat "waits".
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: Rattle Can woes
bartamos #1372014 Tue Aug 04 2020 02:09 AM
Have you bought your lottery ticket yet? wink You must be living right.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Rattle Can woes
klhansen #1372021 Tue Aug 04 2020 02:55 AM
General Purpose
9 years?
Re: Rattle Can woes
klhansen #1372023 Tue Aug 04 2020 04:39 AM
Boltergeist
A needle-tip blow gun and 100 PSI of air pressure has cleared a bunch of clogged rattle can tips for me, especially after an overnight soak in thinner.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Rattle Can woes
klhansen #1372028 Tue Aug 04 2020 05:30 AM
General Purpose
Were are talking proactive vs reactive. Both good info. Especially mine.
Re: Rattle Can woes
klhansen #1372193 Wed Aug 05 2020 05:13 PM
Most spray cans are shockingly bad today. If I have a paint color I want to keep and the can goes bad (happens frequently), I will let the can sit still for a few hours or overnight. Then using a sharp awl I'll carefully poke a tiny hole right where the top piece connects the can portion, pointing it away from me. Let all the pressure release and then use an old style beer can opener to make a larger opening and pour everything into small jar (like a pimiento jar). If the nozzle still works, you can do the same thing by turning the can upside down, but often the dip tube gets clogged. When that happens I've learned that can isn't ever going to work right again. Once I have the paint in the jar, I can mix it thoroughly, pour through a strainer into a little airbrush, thin a bit if needed and spray away. Even a cheap Harbor Freight ($10) airbrush will do a much better job than a spray can, is easily adjustable and you can clean it in a wink. The one I have also came with a 3 ounce jar and with no more overspray than it produces, you can paint a while with it.
Another tip: Have a color that is just about right but not quite perfect? Need a bit more white, red, yellow, etc in it? Or do you have a color which would be perfect if it only had silver or gold in it? Get two cans of paint both made by the same company (say Rust-Oleum or Krylon). Drain both into jars and mix as needed. Chances are very good they'll be compatible. Try a bit with a brush until you're happy with the color...then paint with your airbrush.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: Rattle Can woes
klhansen #1372248 Thu Aug 06 2020 01:32 AM
Jon, I've actually thought about putting the paint from a rattle can in a different container. I actually bought a rattle can of Rustoleum and when I went to use it, it was bad right away. Pushed the button and nothing. The nozzle is clean as a whistle, so the valve inside the can must be fubar.
Rustoleum has a guarantee, and I tried sending them a thing with the code on the can for them to replace it, but never got a response. That can will get the pressure release trick when I get around to using more.
Re: Rattle Can woes
klhansen #1372456 Fri Aug 07 2020 04:35 PM
Boltergeist
Harold46 and Bartamos are spot on. I always wipe the nozzle with thinner after painting and I also have a bottle of thinner that I drop the used nozzles into. I have several variations of the nozzles if needed.
Shake shake shake it is the secret to spray cans. One other thing I do when the weather is cold is to put the can in a sink of warm water for about 10 minutes and it makes a world of difference.....and did I say shake shake shake it?
Back some time ago, when the "new" nozzles came out that you do not have to turn the can up side down to clear, I bought a case and had some problems with the nozzles. I called the customer line and gave them a scowling over the situation and they sent me an envelop full, about 20, new nozzles and an apology. Still have them.
Hot Rod Lincoln is also onto a good idea. I haven't had to use compressed air on a paint nozzle but use it on cans of stuff like WD40 when there is lubricant still in the can but no propellant. I put the caps off and using my air nozzle with the small tip I shoot a shot or two of air in the can and can use up the rest of the liquid.......and NO, I haven't blown up a can...yet?!!
Pictures in my Photobucket
52 Chevy Panel
Page 2 of 3 1 2 3
Moderated by  HandyAndy, klhansen
