The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (TPR57C), 171 guests, and 3 robots.
Forums50
Topics120,972
Posts969,792
Members43,809
Most Online1,229
Jan 21st, 2020
Image Posting Policy
IDENTIFY ENGINE 230??
#1371654 Sat Aug 01 2020 06:10 PM
I just purchased a 1969 Chevrolet C10 step side and was told the engine was a 235. When I got the truck the Distributor is toward the front of the engine not in the middle. I suspect this is a 230 engine. I have the casting number as 3921968 and the number just behind the Distributor is F0602PP. Can anyone help me confirm the engine type> The VIN number is CS149 J 864449 if that helps. Thanks Pete
Chevy Pete
Re: IDENTIFY ENGINE 230??
5253chevyman #1371660 Sat Aug 01 2020 06:50 PM
Boltergeist
The only difference in a 230 and a 250 engine is the length of the stroke- - - -they use the same block casting and the bore size is 3 7/8" on both engines.. If you can get a borescope into one of the spark plug holes, look at the top of the piston. The 230 has a flat top piston, and the 250 has about a 1/4" deep dish in the piston crown. You might even be able to check the piston with a long, narrow screwdriver blade with the piston near the top of its stroke.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
5253chevyman #1371722 Sun Aug 02 2020 12:45 AM
Here's your VIN number CS149 J 864449 break down...
C = Conventional Cab
S = 6-cylinder engine
1 = GVW range (3900-5800)
4 = Model (Pickup)
9 = Year (1969)
J = Janesville Assembly Plant
864449 = unit number starting with 100001, so you have the 764,449th unit built for the 1969 model year from the Janesville Plant.
The smallest 6-cylinder available in a C-10 in 1969 was the 250.
Mike B smile
5253chevyman #1371748 Sun Aug 02 2020 03:01 AM
Have a nice day
5253chevyman #1371774 Sun Aug 02 2020 12:30 PM
292's have the fuel pump in the center of the passenger side, the 230/250 has the fuel pump towards the front next to the water outlet hoses. http://img0128.popscreencdn.com/181026728_chevy-292-inline-six-cylinder-engine.jpg This is a 250/230, notice the shorter side covers, https://i.pinimg.com/736x/2f/e3/9f/2fe39f29ac5669f77dfd86cf2b3b25ea--fancy-cars-oil.jpg
Mike B #1371833 Sun Aug 02 2020 10:12 PM
Thanks Mike and Joe. My fuel pump is closer to the distributor but my distributor looks more like the 292 picture. Are they interchangeable?? I couldn't get my bore scope to work today but will keep trying.
Chevy Pete
5253chevyman #1371836 Sun Aug 02 2020 10:21 PM
Boltergeist
Look at the motor mounts. The 292 is the only engine with them offset side to side. The 194, 230, and 250 have mounts directly across from each other, and the same distance from the bellhousing as a V8. The passenger's side mount on a 292 is about 3 inches further forward than the driver's side mount. The HEI distributor with the large diaqmeter housing and cap will fit the earliuer engines with point-type distributors.
Moderated by  Woogeroo
