The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Barnfind1951, Harold41, 65c20kcmo, Hotrod Lincoln, KEVINSKI, Jerry M.), 245 guests, and 3 robots.
Forums50
Topics120,087
Posts961,807
Members43,554
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Interior Sun Visor Installation
#1371680 Sat Aug 01 2020 08:46 PM
I'm looking for directions or tips for installing interior sun visor brackets.
My kids gave me a pair of interior sun visors for my 1952 Chevy Truck. They came from Classic Parts.
https://www.classicparts.com/1947-53-Inside-Visor-Bracket-Zinc-Right/productinfo/25-012/
Do any of you know how to mount the left and right brackets?
I can't find any instructions on the web or videos on YouTube.
Thank you for your wisdom.
Gerard
1952 Chevy 3100 with GM Straight 6 250 engine
Re: Interior Sun Visor Installation
Gerard Braud #1371697 Sat Aug 01 2020 10:17 PM
If you can't easily see where they mount you probably have the headliner covering the hole. On each side there should be a large hole in the metal structure surrounded by three small holes for the screws. When I mounted mine I was going thru a fiberglass headliner but knew the approximate location of the mounting surface. I used an ice pick to locate and then open the holes. I don't have a photo of before installing the headliner, perhaps someone can supply that. In the mean time perhaps these photos (if they show up) will give you the approximate location of the underlying metal mounting surface.
[img]https://www.stovebolt.com/ubbthread...d/Number/21243/filename/IMG_3008.JPG.JPG[/img]
[img]https://www.stovebolt.com/ubbthread...d/Number/21244/filename/IMG_3016.JPG.JPG[/img]
Gerard Braud #1371699 Sat Aug 01 2020 10:19 PM
That’s a good topic to start Gerard. I didn’t know about this forum four years ago when I bought my ‘57 3200 and installed interior visors. I tried my best to hold them in place and swing them around but I goofed because when I swing them to side window they run down hill a couple of inches. I’ll be interested to here the pros explain this.
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated
Gerard Braud #1371740 Sun Aug 02 2020 02:14 AM
I bought sun visors from truckshop and got a template in the packaging long gone now should of kept them
Gerard Braud #1371775 Sun Aug 02 2020 12:57 PM
Tim,
You know that you should keep everything!
Chris
Gerard Braud #1371780 Sun Aug 02 2020 01:30 PM
Hookalatch #1371824 Sun Aug 02 2020 08:26 PM
Thank you for this. A previous owner cut a hole in the headliner and I can't get the bracket to fit.
I'm guessing they cut the hole in the wrong place.
I may have to remove the entire headliner to find the location you described.
When you mounted your visors, did they fit easily?
Brad Allen #1371826 Sun Aug 02 2020 08:34 PM
Brad Allen - I'd love to get the PDF. My email address is gbraud@spamarrest.com
Thank you,
Gerard
Gerard Braud #1371837 Sun Aug 02 2020 10:22 PM
I would say they are a snug fit. You have to be careful with the NOS or originals that you tighten them down equally, if you don’t the ears can break off, trust me on that. I used a sharp punch to locate the three screw holes and for the first hole for the arm, I then enlarged that hole carefully with an X-acto knife. Email is sent, that is quite the spam filter application you have.
Moderated by  ndkid275
