EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
20 members (canadiantim, buoymaker, David Cormier, frogfarmer, 65chevyc10, 69Cuda, 2 invisible),
201
robots. |
Key:
Admin,
Mod
Forums50
Topics122,132
Posts979,690
Members44,158
Most Online1,229 Jan 21st, 2020
 Re: Well dang it all to heck!
OP
Hold your horses, boys. We found out what caused the flange to separate from the water pump shaft, and it was not from an underpaid offshore worker. It was caused by a an American. Two years ago, while mocking up the fan-to-radiator clearance, I found that the spacer which I bought was too thick. I bought one which was 1/2" thinner and went to bolt it on. I had trouble holding the pulley, spacer, spacer bushing, fan all together while screwing in the bolts. Who doesn't? I finally got two of them in far enough to hold everything in place. I tightened those two bolts, to once again check clearance from radiator. As I got close to having the slop taken out of the parts, it became harder to turn the wrench. I went back and forth a few times without any success, them it dawned on me that the bolts for that original, thicker spacer might be too long, so I replaced them with shorter bolts and everything tightened right up. Guess what makes an excellent water pump flange puller? Two bolts which are 1/2" too long. A friend of mine had come over to help me figure out what could have gone wrong. He was the one who saw the two scores caused by the too-long bolts in the water pump right below where the flange goes. The flange was not perceptively loose after the American did this to my truck, so I can't be too hard on him, in spite of his habitual dickishness.
I guess that American is buying you a new radiator then.
Kevin First car '29 Ford Special Coupe #2 - '29 Ford pickup restored from the ground up. Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] Busting rust since the mid-60's
Ah, well...sorry to hear about that also.
Jon
1952 1/2 ton with 1959 235 T5 with 3.07 rear end
Crusty Old Sarge
Well you know sometimes you just need to tell on yourself. I haven't had a water pump issue but I have broken off a bolt in the front of a cam shaft, you know "Just a little tighter".
Craig
Come,Bleed or Blister somethings got to give!!! 59' Apache 31, 327 V8, Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Thanks Carl for fessing up. Shows you have a lot of character. Anyone who has turned a wrench has pulled a bone headed stunt at least once.š
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ā65 Chevy Biscayne 4dr 230 I-6 one owner (Iām #2) ā39 Dodge Businessmans Coupe USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop!
Dang American labor! Unforeseen consequences, story of my life.
Good luck with the repairs.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1951 Farmall Super A
Boltergeist
Back in the dark ages when I ran a shop in California, I was doing a valve job on an overhead cam Porsche 914, the one with the flat 6 cylinder rear engine. I thought it would be a good idea to pre-tighten the big nut on the end of the camshaft holding the sprocket on with an air impact wrench before doing the final tightening with a torque wrench. Cast iron Porsche cams don't like to be hammered on, it seems- - - - -the nut, and the threaded cam snout along with it, launched itself across the shop. $450.00 later, the engine got assembled with a new cam! Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
