The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
21 members (55 SHAKER, 55_2nd_Series, canadiantim, buoymaker, David Cormier, frogfarmer, 2 invisible), 211 guests, and 3 robots.
Forums50
Topics122,132
Posts979,693
Members44,158
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Well dang it all to heck!
52Carl #1370797 Mon Jul 27 2020 02:08 AM
52Carl Offline OP
Hold your horses, boys.
We found out what caused the flange to separate from the water pump shaft, and it was not from an underpaid offshore worker.
It was caused by a an American.
Two years ago, while mocking up the fan-to-radiator clearance, I found that the spacer which I bought was too thick.
I bought one which was 1/2" thinner and went to bolt it on. I had trouble holding the pulley, spacer, spacer bushing, fan all together while screwing in the bolts. Who doesn't?
I finally got two of them in far enough to hold everything in place. I tightened those two bolts, to once again check clearance from radiator.
As I got close to having the slop taken out of the parts, it became harder to turn the wrench. I went back and forth a few times without any success, them it dawned on me that the bolts for that original, thicker spacer might be too long, so I replaced them with shorter bolts and everything tightened right up.
Guess what makes an excellent water pump flange puller? Two bolts which are 1/2" too long. A friend of mine had come over to help me figure out what could have gone wrong. He was the one who saw the two scores caused by the too-long bolts in the water pump right below where the flange goes.
The flange was not perceptively loose after the American did this to my truck, so I can't be too hard on him, in spite of his habitual dickishness.
52Carl #1370801 Mon Jul 27 2020 02:26 AM
I guess that American is buying you a new radiator then. wink
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
52Carl #1370810 Mon Jul 27 2020 03:19 AM
Ah, well...sorry to hear about that also.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
52Carl #1370833 Mon Jul 27 2020 12:00 PM
Crusty Old Sarge
Well you know sometimes you just need to tell on yourself. I haven't had a water pump issue but I have broken off a bolt in the front of a cam shaft, you know "Just a little tighter".
Craig
Come,Bleed or Blister somethings got to give!!!
59' Apache 31, 327 V8, Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
52Carl #1370835 Mon Jul 27 2020 12:39 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Thanks Carl for fessing up. Shows you have a lot of character. Anyone who has turned a wrench has pulled a bone headed stunt at least once.šŸ›
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
52Carl #1370845 Mon Jul 27 2020 01:33 PM
Dang American labor! Unforeseen consequences, story of my life.
Good luck with the repairs.
RonR
1970 340 Duster
1951 Farmall Super A
52Carl #1370846 Mon Jul 27 2020 02:07 PM
Boltergeist
Back in the dark ages when I ran a shop in California, I was doing a valve job on an overhead cam Porsche 914, the one with the flat 6 cylinder rear engine. I thought it would be a good idea to pre-tighten the big nut on the end of the camshaft holding the sprocket on with an air impact wrench before doing the final tightening with a torque wrench. Cast iron Porsche cams don't like to be hammered on, it seems- - - - -the nut, and the threaded cam snout along with it, launched itself across the shop. $450.00 later, the engine got assembled with a new cam!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Page 2 of 2 1 2
Moderated by  KCMongo
