Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
15 members (Gdads51, Dusty53, cmayna, COCOE, 32vsnake, 2 invisible), 157 guests, and 3 robots.
The Zone
Forums65
Topics123,390
Posts998,855
Members47,294
Most Online1,229
Jan 21st, 2020
Page 3 of 10 1 2 3 4 5 9 10
Smangy Offline OP
I guess on stick gir the tranny and the other for
the 3 speed power divider.
I dont know if it has air brakes.
Once I get more pics I'll post
3B, did Canadian GMC use the same Power Divider that Chevrolet (USA) used? The shift levers look a little different to me.
That's a neat truck and would be the only on at the Sunday morning cruise -in!
Post some pictures of the power divider and the rears when you can.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod [stovebolt.com]
1956 8400 Wrecker w/Holmes 525 [stovebolt.com]
1956 9200 Tractor w/Allison Automatic [stovebolt.com]
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 CJ-5 Navy Jeep
Hughesville, MD
Is that an optical illusion, or are there actually three shifters in that cab? What's that funny-looking curved stick for? I can see the main shifter and the Brownie clearly, but is looks like there's another one there also.
“Grease Monkey” “Former herder of cats”
Your passenger can help row that boat! 🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
If lt has air brakes, that will be a plus, older hydraulic brakes are difficult to find parts for, everything rusts because of brake fluid.
Ed
3B Offline
Hy Guys, Mike as far as I know the driveline components on those tandems are the same on both sides of the border. Hotrod Lincoln the third lever is what they call a declutching lever, in one position only the front axle of the tandem is being driven, in the other position both axles are being driven. I do not recall seeing an air compressor in the engine compartment, but I will go back and check, without that compressor no air brakes or air over hydraulic brakes. I would not mind having that truck join my rust collection myself, but I hope Smangy buys and preserves it. Hope that helps.
Smangy Offline OP
Thx everyone for the good info.
Really wanna pick it up, hope wife doesnt kill me too many projects already.
The seller takes forever to get back to me online. He must have no signal up there in the north pole.
Also found this info online. It's from a chevy but the same I guess.
Smangy Offline OP
Hotrod lincoln
What the meaning behind user name????
3B Offline
Hy guys, I just went back and checked the pics, no compressor, but a power steering pump, so rare power steering, definitely a 348/409 style engine. I hope Smangy or someone grabs it and preserves it.
Smangy Offline OP
The seller sent me more pic.
Fenders rusted and the cab above the windshield is rotted. Sucks.
