The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Roxxstar, Johnny N, Oilyrider1951, Otto Skorzeny, Tiny, 1 invisible), 159 guests, and 3 robots.
Forums60
Topics125,015
Posts1,008,935
Members45,121
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Semi-Fluid Grease for Steering Gearbox
#1357085 Sat Apr 25 2020 04:04 PM
drdoug Offline OP
Chevron Delo EP NLGI 00 Semi-Fluid Grease for vintage manual steering gearboxes.
$24 per 1.875 pound container (approximately 1 quart), plus shipping, or
$13 per standard 14 oz. cartridge, plus shipping.
Shipping typically runs between $9-$11 for up to four 14 oz. cartridges or two 1 quart-size containers (zip code needed to quote shipping).
PayPal preferred payment method.
This is a superior, synthetic semi-fluid (self-leveling) grease for all vintage steering gear applications. Its specs exceed that of the commonly used Champion “00” and Penrite Semi-Fluid Steering Gear Fluid from Australia (which surprisingly at manufacturer stated 18 pounds, doesn’t meet EP minimum standard of 40 pounds for Timken OK Load test, per ASTM D 2509). The base oil viscosity is equivalent to 90 weight gear oil, which was the original spec for many GM steering gearboxes. It will flow somewhat better than the commonly used John Deere “Cornhead” grease, which is NLGI 0 rated. It should not leak as does 90 weight gear oil from vintage steering gearboxes in normal condition and operation.
Since it is available from Chevron in a minimum 35 pound (5 gallon) pail, this is excess material well over and above my needs, recently acquired and repackaged in my shop in fluorinated HDPE quart containers which are suitable for long-term storage of oil and grease products. Based on several requests, I have also repackaged some of the grease in in standard 14 oz grease cartridges as well as the quart bottles. The cartridge tubes are brand new, metal seal on one end and plastic cap on the other. They are HPDE lined for safe long-term storage of grease. Each container is sealed and labeled with the Chevron Smart-fill labeling system code for Delo EP 00 grease. Limited supply.
A copy of the Chevron Product Data Sheet (PDS) and MSDS will be included in the shipment. Send a PM for more details!
Re: Semi-Fluid Grease for Steering Gearbox
drdoug #1369517 Fri Jul 17 2020 07:34 PM
what is the capacity of our steering boxes?
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
drdoug #1369524 Fri Jul 17 2020 08:06 PM
drdoug Offline OP
Patrick, most of the AD trucks and stovebolt-vintage cars use about one cartridge (a little less than half of a quart) for a steering gearbox fill. Not sure if the big bolts use more, but for your 1/2 ton, a cartridge should do it.
Doug
drdoug #1384292 Thu Nov 12 2020 08:42 PM
drdoug Offline OP
Still available, a limited amount of Chevron Delo EP NLGI 00 Semi-Fluid Grease for vintage manual steering gearboxes. Specs are shown in the first post.
Doug
drdoug #1384353 Fri Nov 13 2020 01:21 PM
Sent you a PM Doug
drdoug #1407081 Thu Apr 22 2021 06:20 PM
drdoug Offline OP
Update: I still have a bit of the Chevron Delo EP 00 semi-fluid grease available - repackaged and labeled with Chevron's SmartLabel system - in quart-size container or standard 14 oz grease gun cartridge, for anyone who might like to try it for steering gearbox use. Its characteristics are very similar to the NLA GM steering gearbox grease. This is excess above my needs that I am making available since the minimum container size from Chevron is a 5 gal pail. There is more information in the first post of this thread. Prices cover my cost including the containers.
Shipping usually runs $9-11 for up to 4 standard 14oz grease cartridges or 2 quart-sized (1.875lb) jugs.
PM if interested in more info.
Doug
drdoug #1419497 Thu Aug 05 2021 01:07 PM
drdoug Offline OP
Update: I am down to the last five standard 14 oz grease gun cartridges of the Delo EP 00 semi-fluid grease - repackaged and labeled with Chevron's SmartLabel system - for anyone who might like to try it for steering gearbox use. I am sold out of the quart-size jugs.
The characteristics of the Delo EP 00 are very similar to the NLA GM steering gearbox grease. This is excess above my needs that I am making available since the minimum container size from Chevron is a 5 gal pail. There is more information in the first post of this thread. Price covers my cost including the containers.
Shipping usually runs $9-13 for up to 4 standard 14oz grease cartridges.
Doug
Moderated by  John Milliman
