The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (68ironhead, Bob Kirk, 55shaker, greenie-reddy, 3 invisible), 116 guests, and 3 robots.
Forums60
Topics124,608
Posts1,005,717
Members44,984
Most Online1,229
Jan 21st, 2020
Image Posting Policy
leather vs plastic
#1369397 Thu Jul 16 2020 11:04 PM
I'm pretty much a traditionalist when it comes to my Model B's but, with this last calamity stale ethanol. A recently rebuilt carb about a year ago. Which accelerator pump, leather or plastic?
Re: leather vs plastic
Doc.Hall #1369416 Fri Jul 17 2020 12:59 AM
My B still has the leather, it's gotta be at least 10 years or more with that same accelerator pump. smile And that's running nothing but ethanol gas for the last 5 years since moving to northern AZ (that's all there is here). Last carb rebuild was 2015 but that kit's accelerator pump was dried out leather that had shrunk too much. So I reused my old one. thumbs_up
2 Chronicles 7:14
1952 Chevy 1/2-ton 3100
Dalton Highway survivor
www.truckwithaheart.com [flickr.com]
Doc.Hall #1369435 Fri Jul 17 2020 03:03 AM
Leather has some remarkable properties which are hard to beat with synthetic materials.
An example that fascinates me is that pressure washer pumps use leather seals on the ceramic pistons because they can put up with the extreme heat when a dummy leaves the pump running with the spray gun off. This creates a lot of heat which synthetic materials cannot withstand as long as leather.
Doc.Hall #1369436 Fri Jul 17 2020 03:09 AM
Leather will last longer, however some of the plastic ones I looked at 2 years ago were pretty decent and might actually be ok. I can't offhand recall where I bought them...may have been the place specializing in Quadrajets, but they were better than the others I've seen.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Doc.Hall #1369459 Fri Jul 17 2020 12:35 PM
Carburetion specialist
Leather is better!
When a new leather pump is installed, it should have a few drops of light machine oil applied before installation. And then use a sleeve to hold the leather in place during the installation so it doesn't turn upside down.
When an old leather pump is removed (if the leather has not turned upside down from poor installation) a few drops of light machine oil will generally rejuvenate the leather and it will still be superior to the artificial pumps.
Of course, even a leather accelerator pump won't turn the Rochester B into a real carburetor! nanner
Jon.
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
[image]http://www.thecarburetorshop.com/Avatar.jpg[/image]
Doc.Hall #1369639 Sat Jul 18 2020 06:51 PM
Thanks guys, I have been called a Model "B" Nazi but recently I'm more tended to agree with Jon. Model "B's" are kinda like the bumble bee's....not supposed to fly. Ed
Moderated by  Woogeroo
