The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (TooMany2count, doyle1950, 65c20kcmo, 1 invisible), 250 guests, and 3 robots.
Forums50
Topics120,075
Posts961,667
Members43,548
Most Online1,229
Jan 21st, 2020
Image Posting Policy
47-51 Driver's Door Latch & Outside Handles
#1366621 Sat Jun 27 2020 04:42 AM
Would like to get a decent original latch in case my effort to repair mine fails.
I'm going to try building up the worn striker and safety catch with weld.
Also looking for outside handles. Mine are pitted and the shaft on the driver's side is badly worn.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: 47-51 Driver's Door Latch & Outside Handles
klhansen #1366944 Mon Jun 29 2020 10:22 AM
Hi Kevin, What year is your truck? The strikers should be the same 47-54 but the handles changed. Gerry Lee
klhansen #1366956 Mon Jun 29 2020 01:23 PM
ace skiver
If the "latch" is called the "striker" by GM, the 47-51 striker [plate ?] [chevy.oldcarmanualproject.com] is different from the 52-55st striker [plate].
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
klhansen #1367014 Mon Jun 29 2020 06:00 PM
What I'm looking for is a LOCK (The part that goes in the door) and the pull-down style handle for my '51 pickup. PN 3684167 on this page [chevy.oldcarmanualproject.com]. They were the same from 47 thru 51 as Tim said. in '52 Chevy went to the pushbutton handles.
Probably what I called the striker in my first post should probably be more correctly called the bolt. I'm testing my welding and grinding skills on this one.
klhansen #1368853 Mon Jul 13 2020 01:02 AM
Bump
Anyone?
Moderated by  Tiny
