The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (Mickey3100), 169 guests, and 3 robots.
Forums50
Topics121,036
Posts970,299
Members43,817
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Gmc 51 transmission crossmember
#1368649 Sat Jul 11 2020 12:20 PM
OskarS Offline OP
Hallo,
Im working on a 51 gmc pickup projekt. I have found out that it is missing the transmission crossmember. It has the manual 4 speed transmission witch i understand dosent have any crossmember mount on it original. So my question is, is it okej to drive it like this? Or does it weaken the frame to mutch?
Thank you/ Oskar
Re: Gmc 51 transmission crossmember
OskarS #1368655 Sat Jul 11 2020 12:40 PM
There are several Prior posts on the trans cross member debate. Some Factory shop manuals make no mention of the trans member for the 1/2t model. While 3/4 t and up a call out the trans cross member. There are many trucks running around without the trans member so that’s the debate.
Mine was “missing” with 4 speed conversion. Missing ( not there) Made no difference in use. I did add a aftermarket cross member as an “exercise”. It also made absolutely no difference.
My 1/2t GMC there was no evidence that the transmission cross member was ever present.
Use search to find the prior posts:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=603023&page=all
OskarS #1368657 Sat Jul 11 2020 01:06 PM
OskarS Offline OP
Okej, thank you! There is really no signs of it on mine either, just that the holes for it are there. Found a picture of it in another frame, thats what started my thoughts about it. Il run it as it is then smile
OskarS #1368667 Sat Jul 11 2020 02:23 PM
Would it hurt to install one? I've always had one in my '50 and can't imagine not having one.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
OskarS #1368701 Sat Jul 11 2020 06:40 PM
OskarS Offline OP
If i could find one easy i would but as i live in sweden i dont think i will find anyone here. I would have to make a new one, thats why i asked. If i dosent really mater il concentrate on the rest of the work instead smile Mayby make a new when i know that this is the drivetrain that i really want to stick with in the long run
Moderated by  SWEET
