The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (50wudy, EdPruss, Johnny N, Dusty53, Forty9, Apache1), 328 guests, and 3 robots.
Forums47
Topics117,833
Posts942,919
Members43,050
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 427 Tall Deck... Pros and Cons?
#136848 Sun Jan 21 2007 02:55 AM
The tall deck block is 5/8 taller.It will except an overbore around .160 .Install a 454 shaft , stock length rods,custom set of pistons and you have 496 inches.It has been along time since I have done this but if I remember right Venolia or Keith Black make the pistons.You might inquire about piston heights from the manufacture to get your compression ratio where you want it.Cheap stroker.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#136849 Tue Jan 23 2007 02:52 AM
Wow, I had no idea it would be that easy to stroke. I might just do that. The weight of the motor is really not that big of a difference (50# from the 235), so I think I will stay with it. I am too excited!
Much too young to feel this damn old?
56 GMC
Camaro Clip
C-Notched and Boxed
4 link out back
427 BBC, 400 trans, 9in rear
#136850 Tue Jan 23 2007 06:31 AM
Tallblock pros and cons
pros: tons-o-torque
cons: won't rev for long
Or you can build a 496 stroker,run 8:1 forged pistons and an 8-71 blower at 10% underdriven and make some really impressive torque. eek grin
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#136851 Tue Jan 23 2007 02:20 PM
Just a piece of advice from a person who has spent all the inheritance money of his rich uncle when he got out of the "poor house".
"There is no substitute for cubic inches except cubic money!"
#136852 Thu Jan 25 2007 11:53 PM
Junior Member
As far as the tall decks go in stock form , once you get that 80lb flywheel off of it & get rid of the govenor carb it does pretty good . We put a few of them in 1/2&3/4 ton pickups with good results. Change camshaft and a set ot headers does wonders. Some of them have tiny valves and a
head change really helps. All said they make a great torque motor. Around here you can find them pretty easy [ cental Pa. ]
Have A Good Day --- Fergy
#136853 Sat Jan 27 2007 04:19 PM
good heads and a matching cam can easily put you over 500 hp with the stock stroke
2003 ford lightning
1959 chevy 36
Page 2 of 2 1 2
Moderated by  KCMongo
