The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 members (bluesman, 66flea, archburycontrol, Bolter Finally, CrowbarBob, banjerpikr, 1 invisible), 241 guests, and 5 robots.
Forums47
Topics117,646
Posts941,139
Members43,017
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
427 Tall Deck... Pros and Cons?
#136838 Fri Jan 19 2007 12:04 AM
For all you High Octane boys in the crowd, what is the deal with this motor?
56GMCRat
Much too young to feel this damn old?
56 GMC
Camaro Clip
C-Notched and Boxed
4 link out back
427 BBC, 400 trans, 9in rear
Re: 427 Tall Deck... Pros and Cons?
#136839 Fri Jan 19 2007 01:38 AM
366 396 402 and 427 truck motors. Guys building big inch strokers sometimes use them. The taller deck moves the heads up and out,so you need more space. Uses a differant intake and distributer. all I know about them.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#136840 Fri Jan 19 2007 01:50 AM
Only amde in the 366 and 427 cid, no 396, 402, or 454. GM did make a few 500+ cid crate engines based on that block, also the DRCE pro stock block is based on it. The only real pro to using the tall deck on a street engine would be if you're going for big cubes (600+), otherwise, it's just extra weight. As HevyHaler stated, they use a different intake and distributor. This is due to the taller deck hight. Not much in the line of intakes being made, I have seen stock bbc intakes made to fit using spacers. If you're looking at one (I recall from another post you were), if the price is good (Cheap/free) it will work fine and be a good stout engine. Just don't expect to make a hi-power screamer out of it without doing some serious race type mods.
Bill Burmeister
#136841 Fri Jan 19 2007 02:21 AM
I see... It was a great price, but I was looking to make a hot street motor out of it.
I have done research in the last hour of so and found that the tall deck is a 4 bolt main, which not all bbc are, and comes factory with a forged steel crank...
I would like to build it 450+ hp, but still would like to keep it streetable... Would I be better off trading for a regular bbc?
56 GMC
Camaro Clip
C-Notched and Boxed
4 link out back
#136842 Fri Jan 19 2007 02:39 AM
Not necessarily. The tall deck is a good engine, especially if you want to build a stroker engine. You could put a longer stroke crank, or have the original stroked at the machine shop, and pick ip alot of torque and hp and still keep it on pump gas. The only real major hangup would be any parts that rely on the block hight/width, such as the cam drive, intake, pushrods, and the distributor. Only the intake might have some availabilty issues. Check out Summit or Jegs. You should be able to find parts there for hopping up that block.
As far as a space issue, it shouldn't be much different than a standard big block, might be a little better on the exhaust side due to being higher. Before you redo the block, strip it dowm to bare block (easier to handle) and mock it up in the frame to see where there's any clearance issues so you won't have any surpises.
I guess what I'm trying to say is go for it. You can make a good steetable torque monster with that block, and as I said, keep it on pump gas.
Bill Burmeister
#136843 Fri Jan 19 2007 02:46 AM
That is perfect LONGBOX! Just what I needed to know. I did not even think about JEGs. This is exactly why I am apart of this site. Thank you again.
Now, what should I do about the front end to suport the bbc?
56 GMC
Camaro Clip
C-Notched and Boxed
4 link out back
#136844 Fri Jan 19 2007 06:53 PM
From what I have found there is not a lot of difference in weight between a BB and our 216,235,and 261s. Not long ago I asked the weight of a 261 and was shocked.
user
#136845 Fri Jan 19 2007 11:17 PM
Do you remember the weight? I would like to know...
56 GMC
Camaro Clip
C-Notched and Boxed
4 link out back
#136846 Fri Jan 19 2007 11:28 PM
#136847 Sat Jan 20 2007 12:41 AM
Hey 56
If all you are looking for is 450 - 500Hp why not build a 400 sbc and not take the weight hit. As someone said in an earlier post, those blocks were some times used to build big inch strokers, if your going to only have 427ci its not worth it. Just my 2 cents.
Sean
doing what you love is happiness
loving what you do is freedom
Page 1 of 2 1 2
Moderated by  KCMongo
