The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (CrowbarBob, Xena, JiMerit Boltr#43, reidy, 1 invisible), 215 guests, and 3 robots.
Forums50
Topics120,033
Posts961,341
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Hurst-style Front Cradle Mount
#1368420 Thu Jul 09 2020 11:27 PM
Frank50 Offline OP
Has anyone used a Hurst-style cradle front engine mount to put a SBC in an Advance Design truck? Lots of discussions about lots of options for this swap, but I have not read of this mount being used in an A D truck. I know it’s somewhat popular in Model A and other brand hot rods.
Thanks.
Professional Novice
Re: Hurst-style Front Cradle Mount
Frank50 #1368427 Fri Jul 10 2020 12:21 AM
I have that in my Task Force school bus, but I have it with a 454. I am going to be changing over to the side motor mounts here in the next month or so. I'm adding power steering to my bus and need the space for the pump.
1956 Chevy School Bus Superior Body
More pix in Photobobucket
Frank50 #1368439 Fri Jul 10 2020 01:47 AM
The frame of an AD truck is likely way to narrow for one of those to fit.
Frank50 #1368567 Fri Jul 10 2020 08:39 PM
This style mount was used in some of the bigger trucks and also in the 1956-60 Corvette sandwiched between the water pump and block. As stated, it is in the way of other accessories like p/s or a/c.
Evan
Frank50 #1368576 Fri Jul 10 2020 09:25 PM
Frank50 Offline OP
Thanks all.
According to the dimensions given on Speedway’s listing for this item, the overall length is 21 5/8”. According to the frame drawing in the 48-51 Truck Shop Manual the outside width of the frame at the front is 25 1/2”, for 3100 and 3600 trucks. It is a little wider where the mount would go. That’s why I thought it might work.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0202.htm
https://www.speedwaymotors.com/Spee...p;utm_content=Speedway%20%20(Feb28_2020)
Professional Novice
Frank50 #1368631 Sat Jul 11 2020 03:03 AM
Boltergeist
If you use the original type rear mounts at the bellhousing, that mount should work well. Suspending an engine and transmission assembly with a front mount and one at the transmission tailshaft housing would put a great deal of stress on the bellhousing, especially if it's made of aluminum.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Frank50 #1368693 Sat Jul 11 2020 05:26 PM
Frank50 Offline OP
Professional Novice
Moderated by  KCMongo
