The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (Abelsclassic, Tommy, RebelJD), 197 guests, and 3 robots.
Forums50
Topics120,566
Posts966,374
Members43,701
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Transmission identification
#1367615 Fri Jul 03 2020 09:14 PM
Hi bolter’s
A friend of mine bought a 3100 deluxe 56
It’s an hydra matic 4 gears and reverse do you think it’s an original type?
He asked me if this kind of transmission got the kick and down if yes it doesn’t operate
Can we find easily such transmission ?at what price ? Where ?
Merci
Alain
Re: Transmission identification
Alainfrenchie54 #1367665 Sat Jul 04 2020 03:40 AM
Boltergeist
Yes, the 4 speed Hydramatic was an option in 56. The kickdown is controlled by a mechanical linkage from the carburetor to the transmission, which also controls shift points. There is a small lever at the top of the driver's side of the transmission near the shift linkage which moves as the throttle is opened and closed. Near full throttle, the lever should reach its full travel and cause a downshift from 4th. to 3rd speed. The linkage is adjustable for length, so you can experiment with lengthening or shortening it.
A Hydramatic is a fairly complex transmission which is difficult to repair, and repair parts are somewhat expensive. One company that deals in obsolete transmission parts is Fatsco in New Jersey. I've done business with them for over 30 years.
https://www.fatsco.net/
Finding someone in France with experience repairing that transmission will probably be more difficult than finding the parts! Good luck!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Alainfrenchie54 #1367682 Sat Jul 04 2020 12:01 PM
What would be the best solution for a new transmission ?
The engine is 265ci v8
Alain
Alainfrenchie54 #1367683 Sat Jul 04 2020 12:05 PM
Curmudgeon
I'm trying to add pictures to Jerry's excellent response.
Second page top shows the hard to find Kent Moore gauge used for initial setting of the throttle lever (throttle pressure).
Third page is a basic description from the old B&M company.
Alainfrenchie54 #1367836 Sun Jul 05 2020 02:35 PM
3B Offline
Hy Alainfrenchie54, that transmission was an excellent piece of engineering, it was used by many manufacturers even Rolls Royce used it for years. In my opinion it is the best transmission that was offered for your friends truck. I would do a lot of research trying to find someone with the experience and equipment to work on and or setup that transmission before I would even consider replacing it.
Alainfrenchie54 #1367852 Sun Jul 05 2020 04:17 PM
Boltergeist
Excellent advice! My father was the first man in Nashville Tennessee to work on automatic transmissions back in the late 1940's. A few years later a former US Army tank mechanic opened a transmission shop. One of the light tanks the army used in WW II (the M5 Stuart) was powered by two Cadillac flathead V8 engines, and used two Hydramatic transmissions!
Moderated by  SWEET
