The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (Dajja, Cosmo, BearsFan315, J Lucas, 59 fleet, carbking), 192 guests, and 3 robots.
Forums50
Topics120,586
Posts966,539
Members43,706
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Just how much better is the 848 head
#1367786 Sat Jul 04 2020 11:03 PM
I have heard this is the higher compression head so how much different then the other heads for the 55 to 62 Engines.
Re: Just how much better is the 848 head
Jeff Ogden #1367795 Sun Jul 05 2020 01:21 AM
Boltergeist
The information I have lists the 54-55 235 which had the pre-848 head at a 7.5:1 compression ratio. 56-57 specifications show up at 8.0:1, and for some reason, the 58-62 engines are supposed to have 8.25:1. To the best of my knowledge, the 848 head was the only higher-compression head during the 56-62 year models so I have no idea where the extra 1/4 ratio came from in 1958. Fuzzy math? Sleight of hand? Who knows?
The 54-55 head can be brought down to 848 combustion chamber volume by milling it .090", but some other tweaks have to be made to prevent valve-to piston interference of the intakes, and some sneaky geometry tricks have to be played with the rocker arms as well. Not a problem for an engine machinist who knows what he's doing, but those guys are getting as scarce as a chicken with lips!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Jeff Ogden #1367803 Sun Jul 05 2020 02:05 AM
The 54-55 5913 head had a combustion chamber volumn of 86.3 or so cc. The 848 head is 79.1. The 848 head entered service in 56, along with the neoprene rear main seal. Tom Langdon and I were on the phone one day, has to be 20 years ago or better. He was still working at gm and he had access to the specifications and looked them up. He also gave me the specs for the two different 261 heads. I have measured a few heads and they all come up to about those numbers. Some a little more, but generally pretty close. So 8.0 for the 57 with the tighter combustion chamber is in the ball park. Where the extra 1/4 point came from 58 and up, I do not know.
Mike
Jeff Ogden #1367806 Sun Jul 05 2020 02:17 AM
Boltergeist
Next question- - - -do those numbers represent "theoretical" or actual compression? A change in cam timing could account for the extra quarter point if the figures reflect actual compression pressures. I've got a 100CC burette on order, so one day soon I'm going to be doing some "measurin' an' cypherin' " on the 216 head. I might do some checking on the 235 and 261 heads I've got as well.
Jeff Ogden #1367829 Sun Jul 05 2020 01:01 PM
The reason I ask is I recently found a 59 or 60 261 that I plan on building and it has a 850 head and wondering how it compares to the 848 head,I do have a extra 848 head on a 56 235.
Jeff Ogden #1367832 Sun Jul 05 2020 01:33 PM
848 is a casting number.
Is there a different part number for the head in different years, because of different amounts removed from the gasket surface?
Jeff Ogden #1367833 Sun Jul 05 2020 01:39 PM
848 is a Higher compression head--I have 2 on 1954 rebuilt 235 engines one in my 49 and 1 in the 51--more power-Bill
Jeff Ogden #1367841 Sun Jul 05 2020 03:17 PM
I've always wondered about that extra 1/4 point of compression. I was hoping one of you guys knew. I wondered if it was a different head gasket design. 56 and newer used the copper sandwich type.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Jeff Ogden #1367842 Sun Jul 05 2020 03:27 PM
Boltergeist
I'm going to be doing some comparison checking soon, mostly on the 216 head, but I believe I've got all the 235 and 261 heads on hand as well. I'll be glad to post the combustion chamber volumes I get for each one. The "true" compression ratio is also dependent on when the intake valve closes as the piston is on its way up the compression stroke. That's why camshaft manufacturers recommend high compression when an engine runs a radical cam- - - -there's less cylinder left to compress as the intake valve duration increases, so "high compression" is simply an effort to get the real compression pressure back to where it used to be with a stock cam.
Moderated by  Woogeroo
