The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 210 guests, and 2 robots.
Forums50
Topics120,033
Posts961,341
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 4 1 2 3 4
Re: broken off lug nuts
37 GC #1367724 Sat Jul 04 2020 04:58 PM
General Purpose
I give it a 50/50 chance of breaking the tool.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
37 GC #1367725 Sat Jul 04 2020 05:00 PM
PB blaster, Heat and that tool may do the trick on stubborn ones.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
37 GC #1367727 Sat Jul 04 2020 05:14 PM
General Purpose
It really doesn't matter if the new wheel stud won't fit in from the back.
bartamos #1367735 Sat Jul 04 2020 06:22 PM
Very true. That can be checked before pulling the axle.
37 GC #1367741 Sat Jul 04 2020 06:55 PM
General Purpose
If I got the broken stud out, I would get the new one in. Maybe drill a hole in the backing plate in the right place. Right size hole for a metal plug. Lots of ways to plug the hole.
It does look like, however, that there is enough space to install stud.
37 GC #1367747 Sat Jul 04 2020 07:52 PM
Be careful, the O'reilly tool is ground to a smaller diameter than axle flanges on the backup side, so make sure it is fully seated, even worthwhile grinding the small radius to large radius to fit axle flange.
Ed
37 GC #1367748 Sat Jul 04 2020 07:56 PM
General Purpose
You can't grind on a loaner tool. You can modify the axle flange a little. Maybe.
37 GC #1367759 Sat Jul 04 2020 09:02 PM
One more thing I discovered- there are different lug bolts. There are different lengths for the knurled shoulder and overall length.
37 GC #1367762 Sat Jul 04 2020 09:10 PM
General Purpose
....and some vehicles have lugs with left hand threads on left side of the vehicle and right hand threads on right side. Pontiac, jeeps, mopar........
37 GC #1367768 Sat Jul 04 2020 09:19 PM
Boltergeist
Swaging is done by upsetting the area of the shoulder behind the thread into a chamfer cut into the face of the axle flange. It more or less rivets the stud into the flange with a special tool on a pneumatic hammer, so if the swage isn't cut away with a special cutter similar to a heavy duty hole saw that fits over the stud, you're pushing the taper through a funnel. That will take two or three times the press force of removing a stud with the swage cut away. That O'Reilly tool might push the old studs out, but there's no way I can see for it to pull the new stud back in. If you try to do it with a lug nut and washers, go ahead and throw the new stud away now- - - -you'll stretch the thread and the stud will break again.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Page 2 of 4 1 2 3 4
Moderated by  SWEET
