The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (TooMany2count, 65c20kcmo, doyle1950), 259 guests, and 3 robots.
Forums50
Topics120,075
Posts961,666
Members43,548
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Found:1/4-20 bolts hex head with phillips used on 48 GMC 248 pushrod cover
#1367430 Thu Jul 02 2020 11:32 AM
DP Offline OP
Found: Looking for (qty 10) 1/4-20 bolts as pictured. They have both the hex head and the recessed phillips slots. They hold on the pushrod cover on my 48 GMC 248. They are used on some other inline 6's but I don't know which ones used them. I could use 10 of them.
1948 GMC 1.5 ton Dump
Re: 1/4-20 bolts hex head with phillips used on 48 GMC 248 pushrod cover
DP #1367519 Fri Jul 03 2020 01:28 AM
Looks like an ACE Hardware item
DP #1367554 Fri Jul 03 2020 11:09 AM
DP Offline OP
Thanks for the suggestion. I have been able to find new ones in metric but surprisingly not in SAE.
DP #1367566 Fri Jul 03 2020 02:23 PM
Go on to bolt depot.com and browse. They have a bunch of things and very easy to navigate. John
1949 gmc 1-ton
DP #1367600 Fri Jul 03 2020 06:58 PM
I found some on McMaster-Carr, but they only had fine thread. frown
I also searched Hillman (the usual supplier for the hardware store bins), and came up short there as well.
Nothing on Bolt Depot either.
FOUND THEM
Phillips Hex Head [fastenersuperstore.com]
Unfortunately you need to buy them in quantities of 3000. That should last you a few eons. wink
Maybe you could call them and see who they supply to for retail quantity sales.
Just working on restoring my google-fu skills. grin
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
DP #1367670 Sat Jul 04 2020 04:30 AM
Aircraft Spruce has some but they don't really give a size.
https://www.aircraftspruce.com/cata...jwt-y6gIV3h-tBh196wvTEAQYBCABEgJEB_D_BwE
MNSmith #1367673 Sat Jul 04 2020 04:57 AM
Those are 8-32 x 3/8" long - shown if you click "show on catalog". The don't carry anything larger than 10-32. The -08 indicates the size and the -6 the length in 1/16ths of an inch.
DP #1367677 Sat Jul 04 2020 11:07 AM
DP Offline OP
Thanks for all the replies and research!
DP #1371932 Mon Aug 03 2020 04:41 PM
DP Offline OP
I still could use these. Thought I had located some but it did not work out.
Re: Wanted:1/4-20 bolts hex head with phillips used on 48 GMC 248 pushrod cover
DP #1371984 Mon Aug 03 2020 10:09 PM
DP, if you get stuck, and if no slot, hex flange bolts would work for you, I have plenty. 1/4-20 x 1/2, Grade 5, zinc. See the photo.
Send me a PM if I can help.
Doug
Page 1 of 2 1 2
Moderated by  Tiny
