The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Gazz, FoodTrucker, Gone, Forty9, 3B, DennisM), 236 guests, and 3 robots.
Forums60
Topics123,387
Posts995,752
Members44,653
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 4 1 2 3 4
Re: 66 Chevy 250 dies at stop signs and red lights....help
Lawman #1367448 Thu Jul 02 2020 02:12 PM
Lawman Offline OP
Yes, I ran the old gas near empty and put new in. All the bolts are tight, manifold and carb mountings. It does have power front discs (installed about 3 years ago) that vacuum hose is installed with hose clamps on both ends. Hose to PCV valve is snug on both ends. I’ve had the timing as high as 10 degrees while working this issue. For years it was set at 8 degrees (I thought it was 4, misreading the timing marks as 1 degree instead of 2). I moved it to six degree because Bartamos suggested that was spec and I wanted to base line the engine to solve the idle issue.
Lawman
Lawman #1367451 Thu Jul 02 2020 02:32 PM
Lawman Offline OP
Any chance a bad PCV could be the culprit?
Lawman #1367515 Fri Jul 03 2020 01:03 AM
Where ever you have a vacuum line, remove the vacuum line and put rubber caps on for testing purposes. This will eliminate the possibility of a vacuum leak from a faulty vacuum activated device.
Lawman #1367592 Fri Jul 03 2020 06:00 PM
Lawman Offline OP
Alright, I’m now convinced no adjustment I can make in timing, idle speed, or mixture will fix this problem. All the vacuums seem solid, all the carb screws, bolts and manifold bolts are tight. I think the gas supply is good and the pump is new. So, I’m going to take the Rochester off, clean and probably rebuild it. There must be something stopped up or flow restricted somewhere. Thanks for all your help everyone.
Lawman
Lawman #1367597 Fri Jul 03 2020 06:38 PM
Sir Searchalot
I don't expect you to do this. There are a few of us who could do this and have done this. BUT............if you could hook up a clean gas can on the passenger's floor and run the hose thru firewall to the fuel pump inlet, it would sure eliminate a lot of possibilities. It would point to pump or carb.
Watch out for careful drivers!!!
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
You can't teach a new dog old tricks.
Lawman #1367726 Sat Jul 04 2020 05:04 PM
Lawman Offline OP
Thanks, but I don’t see what that would accomplish. I’ve already replaced the fuel pump early in this effort because I noticed it had a little drip leak. So that is already new and seems to be pumping, I can see the gas pulsing through the glass in line filter just in front of the pump inlet. The tank itself is about 5 years old, all gas lines are new within the last year including the sending unit and it’s filter sock. I treated the gas with sea foam and ran the gas in the tank nearly empty and replaced with fresh from a different station a few days ago. It doesn’t feel like a fuel supply problem.
Lawman #1367732 Sat Jul 04 2020 05:42 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
As Carl says “It’s never the carburetor.......until it’s the carburetor “. It’s time to dig into that Rochester and see what’s happening.🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Lawman #1367805 Sun Jul 05 2020 02:14 AM
Could there be an electrical problem where the coil is grounding out when you stop?
A simple test would be to connect a test light to the + terminal on the coil and to Ground...make the test leads long enough so the light is visible from the drivers seat and take it for a ride and see if the light goes out when you stop...
Grabbing straws here...
Mike B smile
Lawman #1367808 Sun Jul 05 2020 02:43 AM
That was what I thought, but he didn't think so.
Ed
Lawman #1367828 Sun Jul 05 2020 01:00 PM
Sounds like a likely possibility. Should definitely be checked.
Page 3 of 4 1 2 3 4
Moderated by  Woogeroo
