The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (buoymaker, 55shaker, bwilliams, Barnfind49, 3 invisible), 251 guests, and 4 robots.
Forums60
Topics123,387
Posts995,757
Members44,653
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 48 of 55 1 2 46 47 48 49 50 54 55
Re: What was the last tool you bought?
MNSmith #1362228 Wed May 27 2020 02:57 PM
Bought some of those hex drive drill bits the battery drill chucks scuff up your bits so bad when they slip ...an old machinist told me to soak the drill press chuck (jacobs)in diesel fuel just lower it into a can of D.F. for the weekend. Also said tighten all three positions on the chuck ! with diesel lube works good helps protect your number and letter bits !
MNSmith #1362425 Thu May 28 2020 01:40 PM
Just bought a new Ingersoll Rand 90 degree die grinder. My Harbor Freight one still works but does not have the safety lock trigger and was always concerned for an accident to happen. The IR is much quieter and more powerful. So powerful that it shreds roloc discs very easily @ 90 psi.
$54.00 on Amazon.
1951 Chevy 1/2 ton
MNSmith #1362457 Thu May 28 2020 05:57 PM
MNSmith Offline OP
That can make you jump! When you set down a die grinder and it starts operating on its own!!
MNSmith #1362463 Thu May 28 2020 07:02 PM
Very timely,
I was operating a HF die grinder yesterday with a carbide bit inside the cab. . Set it down on a HF moving blanket and next thing you know leaned on the trigger and it went full tilt, luckily it spun into the blanket and stalled itself. It would of been a mess if I would of hit it directly with my butt cheek. Definitely will be being more careful in the future.
Steve
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
MNSmith #1365395 Thu Jun 18 2020 11:22 AM
An excellent gun screw driver set, my Craftsman drivers have been well taken care of. Hand me downs from my dad and brother. They do wear out after 56 years. Doc
MNSmith #1367433 Thu Jul 02 2020 11:43 AM
Crusty Old Sarge
Just bought an Eastwood Contour SCT, it's a drum type sander/stripper. the online reviews were great. I'm going to try it out on my leaf springs this weekend, I'll let you know about the results.
Contour SCT
Craig
Come, Bleed or Blister something has got to give!!!
59' Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
MNSmith #1367494 Thu Jul 02 2020 09:51 PM
The last three;
Knipex adjustable wrench. Fantastic
Channel Lock cutting pliers. Great
HF Spline Splicer. Unused as of yet
"Sedgewick"
1949 Chevy 1/2-Ton
1989 Caprice
MNSmith #1367543 Fri Jul 03 2020 03:13 AM
MNSmith Offline OP
I picked up a little ring, dolly, pointer, hammer head type of body dolly. Hopefully, it will help get in to those tight spots.
MNSmith #1367570 Fri Jul 03 2020 03:25 PM
I just purchased a better wet/dry vaccuum, 6 point deep and standard impact sockets (imperial), ratcheting wrenches, a nice breaker bar, and some needle-nose pliers.
1951 Chevrolet 3100
MNSmith #1374270 Fri Aug 21 2020 02:02 PM
Local FB marketplace purchase. Paid $5 and it actually works and has the original owners manual! This one is more compact than my other Sears model. The last one is much quicker for a spot check.
Moderated by  48bigtrucks, MNSmith
