The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (2ManyTrucks, agedhorse, North of 40, Eureka Jim, tomctomc), 226 guests, and 3 robots.
Forums50
Topics120,060
Posts961,569
Members43,548
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 5 of 5 1 2 3 4 5
Re: How to get rings to seat in a rebuilt engine?
Lugnutz #1367149 Tue Jun 30 2020 03:25 PM
Those are used at every airport to check the valve and ring conditions of recip engines using 80 psi as the baseline.
Ed
Barnfind49 #1367166 Tue Jun 30 2020 05:18 PM
Originally Posted by Barnfind49
I highly doubt this thing was actually “rebuilt”. Unless rebuilt means yea we tossed a set of parts store rings and rod bearings in it so it all new now.
Otherwise know as a "repaint".
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Lugnutz #1367169 Tue Jun 30 2020 05:28 PM
Boltergeist
We used to call that a "Rattle Can Rebuild" back in the dark ages- - - - -low-budget used car lots would buy a junkyard engine, swap a few gaskets, and give it a quick paint job, and have some minimum wage wrench jockey drop it in and do a quick tune-up. Of course, the car was sold 'As Is- - - -No Warranty!"
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Lugnutz #1367251 Wed Jul 01 2020 01:41 AM
Lugnutz Offline OP
Here’s a quick video of my leak down test. CYLINDER 5 VIDEO LINK [youtu.be]
I pressurized the cylinders again tonight and HEARD AND FELT air at the oil fill hole and the intake throttle body. If I also have leaking intake valves, then the cylinder leak down test numbers will be falsely lowered.
The plan for the weekend is to run the engine for a while and test it again when warm. I want accurate info before I ask the engine builder to remedy the problems.
Lugnutz #1367260 Wed Jul 01 2020 02:42 AM
Boltergeist
While you've got pressure on a cylinder, use a dead blow mallet to tap the top of the rocker arms to see if the valves can get a better seal. Sometimes just a couple of thumps can remedy a leak caused by a little debris between the valve and the seat. Worth a try!
Hotrod Lincoln #1367265 Wed Jul 01 2020 03:02 AM
Lugnutz Offline OP
I have the covers back on and it’s ready for another test run Thursday.
I never felt air out the exhaust. I had some air coming back through the intake on at least six of the cylinders.
This engine wasn’t rebuilt properly and the valves seats were messed up too.
I’m gathering proof.
Lugnutz #1367456 Thu Jul 02 2020 02:51 PM
Boltergeist
jay, sounds like you may have a civil suit, ..........or a divorce, in the near future!!
keep us posted and good luck. you get an A+ on doing your homework, time for the dude to payup or suffer the consequences...unless he bellys up to the bar and does what is right!
Pictures in my Photobucket
52 Chevy Panel
Lugnutz #1367462 Thu Jul 02 2020 03:12 PM
Boltergeist
One of my former students did a shade tree "valve job" by coating the valve faces with grinding compound and spinning the valve back and forth with a reversible cordless drill motor while pulling the valve against the seat. He got enough of a seal to get some compression on a worn out engine, filled the crankcase with STP and 90 weight gear lube, and sold the car! I wonder if he might have moved to your neighborhood?
Moderated by  Woogeroo
