The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (buoymaker, dougs, 55_2nd_Series, carbking, 5 Window 9434, 1 invisible), 99 guests, and 4 robots.
Forums50
Topics119,572
Posts957,446
Members43,431
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1952 gmc 102-22 long box. trucks shakes
#1366363 Thu Jun 25 2020 04:06 AM
hello every one i cant seem to get rid of my truck shaking . it feels like front end. but all seems well, just wondering could it be front ball on drive shaft to tight. all is new there as well.i tried to see if it worse when i acelerate or coast seems same. there are no modifications to truck all is stock and drive train rebuilt to new
Re: 1952 gmc 102-22 long box. trucks shakes
mikebrou #1366364 Thu Jun 25 2020 04:25 AM
must add i read a lot on forum on this issue. just would like to know if ball tightness could cause this.
mikebrou #1366379 Thu Jun 25 2020 11:55 AM
Get someone to sit in the driver's seat and cycle the steering wheel while you look at every item in the steering system. Also while there look for things like broken leaf springs, loose or broken shackle mounts, etc.
That would be a place to start. If you still think it is in the drivetrain, jack up the rear axle, put it in gear and have someone else carefully observe the running gear.
Ed
mikebrou #1366407 Thu Jun 25 2020 03:01 PM
Don’t rule out the tires. It’s hard to get a good set of tires these days that don’t warble on city streets at 25 mph. I tried two different sets of Michelin Defenders and a set of Bridgestone’s on a 2016 Explorer after the original factory junk wore out. Finally traded vehicle because we just didn’t like it overall. I’m thinking I’ll go with Coopers on my ‘57 Chevy 3200 when it’s ready.
Last edited by DES57; Thu Jun 25 2020 06:12 PM. Reason: Changed Firestone to Bridgestone
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated
mikebrou #1366493 Fri Jun 26 2020 03:08 AM
thankyou all for the suggestions i will try them this week. if its tires its so difficult up here to get 700/15 or 670 /15. i have stock split rims 15 inches.i can get them from the stats but 350 each for mewith mounting 1600.but DES57 you may be right
mikebrou #1366497 Fri Jun 26 2020 04:25 AM
You can find 15" 1 piece wheels for 6 lug GM pattern in lots of widths, 5 to 5 1/2" width should be about right for those tires.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
mikebrou #1366518 Fri Jun 26 2020 12:51 PM
Shakes on the road at speed.........tires and king pins.........are prime suspects.
mikebrou #1367019 Mon Jun 29 2020 06:14 PM
Yes showkey, I usually put old yeller on jack stands with an L shaped piece of steal and attach a piece of chalk close to tire using a small vice grip. With tire turning slowly push chalk unit all the way across. If chalk is either light to heavy take to a tire/wheel shop that trims tire to a true round with a cutter. Doc.
Currently making 1954 3100 better than new
mikebrou #1367158 Tue Jun 30 2020 04:42 PM
bc 59 thankyou again ill keep looking. what engine to you have in 54.
mikebrou #1367201 Tue Jun 30 2020 08:07 PM
Tires will flat-spot if left sitting in one position too long. Especially true for bias plies.
1951 Chevy Panel Truck
Page 1 of 2 1 2
Moderated by  Justhorsenround
