The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Chris McKenna, EdPruss, 3B, 51sub, 2 invisible), 107 guests, and 3 robots.
Forums50
Topics119,573
Posts957,448
Members43,431
Most Online1,229
Jan 21st, 2020
Image Posting Policy
What should this be connected to (now with photo)
#1366506 Fri Jun 26 2020 09:51 AM
reidy Offline OP
Hello,
I have a 1941 Holden build Chev truck in a partially disassembled state. It is an old farm truck. On top of the chassis rails close to the steering box, and a similar point on the the other chassis rail there is also a bolt that secures a very long eye bolt type thing. The eyes are held by the bolts but a shafts runs forward almost to the radiator where there are threaded connectors.
Obviously something must have screwed into these connectors. The shafts are sitting almost flat against the chassis rails but if they were left undone and the truck was driven the would eventually straighten and settle flat.
My guess is that the connected somewhere to the radiator support but I am not sure where. The sit just inside the wheel arch splash panels.
Steve
Re: What should this be connected to
reidy #1366514 Fri Jun 26 2020 12:21 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Photos would really help us help you. Instructions are in the left margin of every page.šŸ›
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
reidy #1366625 Sat Jun 27 2020 05:57 AM
reidy Offline OP
Thanks for the reply.
I have attached a couple of photos. It is the bit on top of the chassis rail I am talking about.
Steve
reidy #1366641 Sat Jun 27 2020 12:47 PM
Lift it up about 45 degrees and put a bolt through that bracket on the side of the radiator, however it looks too short as shown unless the radiator needs to be tilted back slightly?
Ed
reidy #1366661 Sat Jun 27 2020 03:03 PM
Boltergeist
Is that a coupling nut or a turnbuckle on the end of the rod? (Turnbuckles have right and left hand threads) It looks like the front piece that would have bolted to the hole at the top of the radiator is missing.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
reidy #1366697 Sat Jun 27 2020 06:24 PM
Sure does, Jerry.
Ed
reidy #1366785 Sun Jun 28 2020 09:55 AM
reidy Offline OP
Thanks for the replies. I was thinking they must connect to the radiator. At least I now know to keep an eye out for the other half at swap meets.
Steve
reidy #1367147 Tue Jun 30 2020 03:14 PM
Boltergeist
If you're not interested in being 100% period-correct, turnbuckles are common hardware store items, and the existing rod could be rethreaded to accommodate the right hand thread part of the new assembly.
Moderated by  69Cuda, Grigg
