EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics121,355
Posts977,513
Members44,208
Most Online1,229 Jan 21st, 2020
 Not a Chevy question.
OP
I have a 1989 Jeep Comanche. It doesn't have a radiator cap. It has a pressure bottle on the firewall. When you drain the coolant you have to burp the system. Have any of you encountered such a thing? I am putting in a radiator with a cap and an overflow bottle this weekend. Hopefully, it will burp its self.
 Re: Not a Chevy question.
I had a 90 Cherokee. That engine will not burp itself. You are supposed to fill the reservoir, bring the engine up to temperature, shut it off and allow it to cool. "Wash, rinse, repeat" as many times as necessary until the reservoir no longer lowers after it cools down. Then you keep your finger crossed that it is right. I almost blew mine up not knowing this.
Boltergeist
Most engines with part of the cooling system above the top of the radiator will have a bleeder screw that can be opened while filling the system. If not, find the highest hose connection and disconnect it while filling to allow the trapped air to be displaced. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
I have heard of running up on blocks while filling or at least get the nose uphill.
They do make a cooling system burping tool.
