The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (olezippi, Chris McKenna, EdPruss, 3B, 2 invisible), 105 guests, and 3 robots.
Forums50
Topics119,573
Posts957,448
Members43,431
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1949 3800 rear brake adjuster
#1367028 Mon Jun 29 2020 07:20 PM
JP3800 Offline OP
I'm just getting into the rear brakes on my 1 ton.
The teeth on one of the adjuster wheels are mostly sheered off - what are the options to repair this? Do I just need to find replacement backing plates?
Re: 1949 3800 rear brake adjuster
JP3800 #1367062 Mon Jun 29 2020 11:57 PM
The part does show up on Ebay. When you can, send me a PM, I may be able to help. I think the challenge would be how to attach the new wheel. I think they were swagged together.
I have often wondered if it is possible to cut a slot in the backing plate and adjust it like the front. The brakes on the front of my 38 Master, which use the same drums as the 1/2 Ton, have a hole drilled in the drum to do the adjustment.
1951 1 Ton Completed
truckernix #1367106 Tue Jun 30 2020 04:49 AM
When I first got my 1-Ton I was delighted to see how easy it was to adjust the back brakes. Just put a wrench on the adjuster and turn it, clockwise to tighten and anti clockwise to loosen. Then I tried it and promptly stripped the teeth on the cam due to rust in the fine threads in the end caps of the wheel cylinder that had frozen tight. I ended up using a brass punch and a small hammer to get the end cap to move. When you put everything back together lightly lubricate the threads so that they can't rust up and it's a fine idea to carefully move the adjusters back and forth a little every so often.
JP3800 #1368638 Sat Jul 11 2020 04:17 AM
It's been a few years now but I once was able to get new the wheel with the pimples on them that engage the ends of the wheel cylinders. I braised them onto the existing shafts with new springs. It has worked for many years now. I have long used Never Seize compound on the aluminum pistons, the threads on the adjusters, front and rear, and anything else I can think of just to ward off the devils of rust. Don't forget the bleed screws in the wheel cylinders.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Moderated by  Grigg
