The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (BC59, Justhorsenround, 9% grade, HFfarms, crenwelge, 2 invisible), 259 guests, and 5 robots.
Forums50
Topics121,526
Posts974,294
Members43,953
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Cooler in the truck bed
#1366972 Mon Jun 29 2020 02:01 PM
Hi Folks, I bought one of these nice coolers to put in the back so when I pickup Food goods, they wont be rolling around the cab. My Question to you folks, I have seen some folks with a cooler or trunk in the bed, how do you mount it, and is it easily removed? I have a 1954 3104 half ton. See picts below.
1954 Chevy 3100
Re: Cooler in the truck bed
Kevin13Shaw #1366973 Mon Jun 29 2020 02:06 PM
ace skiver
What model 3100?
Probably a 3104/pickup?
I'd use a few stainless-steel bolts - through bed-board metal retainer-strip bolt-holes?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Kevin13Shaw #1366992 Mon Jun 29 2020 03:28 PM
When I take a cooler on a short fishing excursion, I just tie it off to the side.
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving but now on hiatus. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Kevin13Shaw #1366994 Mon Jun 29 2020 03:37 PM
I guess one way or another you'll need something permanently mounted to hold it in place. Hooks/loops that would accept a tie down of some nature, or a bracket it would slip into. You sure as heck wouldn't want it sliding around in that sweet looking bed.
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
Kevin13Shaw #1367000 Mon Jun 29 2020 04:41 PM
I shopped for a couple years for a reasonably priced old Coke cooler. Never found one at my price point ($100 or so) that was as nice as I pictured in my mental images. Good ones were in the $300 range. One issue I considered was how to make it somewhat theft resistant (as opposed to the near impossible theft proof). If you come up with a good non-destructive solution, please share.
Good Luck,
RonR
1970 340 Duster
1951 Farmall Super A
Kevin13Shaw #1367004 Mon Jun 29 2020 05:02 PM
Been thinking about a cooler or an old trunk for the back of my 49. Just not sure yet. Would be nice to see some pics of what other have done.
1949 5 Window 3100
Veteran of the USAF
Kevin13Shaw #1367011 Mon Jun 29 2020 05:39 PM
My 46 had a Coleman chest that fit inside a reconditioned steamer trunk. Leather straps and marine spar varnish. bolted to the floor with two 3/8th's stainless bolts. Trunk had a lock from the early 1890's but hay it looked fine for any truck up to 1st 55. Don't try to get one off Ebay it will be way expensive. Have found 3 on Pintrest. Just don't let them keep contacting you after you get your item. Have not paid more than $80.00 for a round top. Usually $ 30.00 to 40.00. Just found a new one on wayfare (dome top), for $74.00. Check it out, will need several coats of spar varnish, also set it on 4, 1/2" oak strips well varnished. Doc.
Currently making 1954 3100 better than new
Kevin13Shaw #1367012 Mon Jun 29 2020 05:49 PM
I have an antique metal cooler and likewise have considered how to secure items in the bed. I think possibly substituting a couple of eyebolts for the plank bolts along with bungees/straps might work. However, you will need to have something under the metal cooler to prevent scratching the finished bed wood. You will also have have unsightly bolts or fasteners in the bed floor…and Murphy’s Law awaits every opportunity for something to come loose. My solution has been to always carry the metal cooler inside, in the passenger side floor secured with a long bungee attached to the seat frame. For car shows, the only items I carry in the bed are my canopy and folding chairs, (bundled together) and these are inside soft padded bags. That’s a beautiful truck you have, - you don’t want to take a chance with that paint & bed finish!
Kevin13Shaw #1367021 Mon Jun 29 2020 06:22 PM
My ‘57 3200 is a daily driver with sheet steel and a rubber pad in bed. You guys with show trucks and keeping it original won’t like this, but it works for me. When I start tearing box off to sand down and repaint the entire truck, I might move these tie downs a little further from the corners. It limits what I tie down straight across the bed. I’ve done corner to corner diagonally ok, but it pulls the straps funny.
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated
Kevin13Shaw #1367033 Mon Jun 29 2020 08:05 PM
That's clever!
don
Page 1 of 3 1 2 3
Moderated by  Justhorsenround
