The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 97 guests, and 3 robots.
Forums50
Topics120,492
Posts965,741
Members43,684
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Thermostatic spring
wokri #1365308 Wed Jun 17 2020 07:06 PM
Wolfgang, the Shop Manual (p. 6-4) has a drawing of the Heat Riser Operation [chevy.oldcarmanualproject.com]. When the flapper valve is in the closed position, routing exhasut gases up under the intake manifold, the counter weight is horizontal. As the spring heats, the counter weight drops toward the engine, going more vertical.
Doug
wokri #1365310 Wed Jun 17 2020 07:13 PM
Please see the attached image. The weight will look like this when it is cold. There will be spring pressure against it at this point. The weight rotates counter-clockwise (as the arrow shows) when the engine is at normal running temperature.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
wokri #1365311 Wed Jun 17 2020 07:20 PM
And here is what the weight will look like when the engine is hot...and an image of the spring. Good luck.
Jon
wokri #1365438 Thu Jun 18 2020 04:13 PM
wokri Offline OP
Thank you for your pictures.
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
wokri #1366940 Mon Jun 29 2020 08:23 AM
wokri Offline OP
One question,
if the engine is cold the flap of the exhaust manifold is open and if the engine is warm the flap must be closed? Is it right?
wokri #1366960 Mon Jun 29 2020 01:29 PM
Total opposite actually.
wokri #1366965 Mon Jun 29 2020 01:37 PM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Page 2 of 2 1 2
Moderated by  Woogeroo
