The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (msmall, Mike Chatman, 5 Window 9434), 129 guests, and 3 robots.
Forums60
Topics123,950
Posts1,000,312
Members44,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Plumbing issue
#1366666 Sat Jun 27 2020 03:11 PM
back yard wrench turner
I know there are many knowledgeable people here. I am looking for a solution to stop water flowing after a set time period.
Yesterday I had a toilet overflow because the flapper hung up on the chain. It ran for 3 hours and filled the septic tank then overflowed into the bathroom. Luckily we got home before any water escaped the bathroom.
I've found automatic flow stops that have sensors that will detect water that has overflowed. What I would like to find is a device that will only let water flow for a set period like 1 minute.
Does anyone know if this is available?
Wayne
1938 1-Ton Farm Truck
-30-Stovebolt Gallery
Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. malmwayne@hotmail.com
Re: Plumbing issue
Wayne67vert #1366673 Sat Jun 27 2020 03:40 PM
Is there a way to incorporate an overflow setup for the septic system for when it gets too high to prevent the water from backing up into the house?
Re: Plumbing issue
Wayne67vert #1366675 Sat Jun 27 2020 03:43 PM
I don't know of anything available commercially, but it would be fairly simple to wire a timer and a solenoid valve that would shut off water flow to the float valve in the toilet after a preset time. A microswitch on the flush handle would start the timer, which could then be set to shut the supply line off after whatever time it's set for.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Plumbing issue
Wayne67vert #1366684 Sat Jun 27 2020 04:27 PM
The last toilet valve I bought has a feature that stops the water from flowing when something sticks. I have no idea how it works but it does work. I got it at Ace.
Edit: I just went and looked. It's the Korky 528.
Re: Plumbing issue
Wayne67vert #1366689 Sat Jun 27 2020 05:18 PM
Further interweb search turns this up: https://www.amazon.com/Water-Block-Excess-Shutoff-Valve/dp/B074V9LL19#customerReviews
It says adjustable from 1 gallon to 13 gallons.
Tiny, the Korky site doesn't show that valve to shut off the water supply line unless the tank is to the fill point. My issue was with an open flapper.
Wayne
Re: Plumbing issue
Wayne67vert #1366690 Sat Jun 27 2020 05:22 PM
Wayne, rather than putting a band-aid on the problem, why don't you just fix the toilet? It doesn't take much ($ or time) to replace all the innards of the toilet tank and get it working like it should. Or you could get one of the new-fangled pressure assist low flush toilets that use 1.6 gal per flush.
My dad owned a plumbing shop and we made lots of calls to fix the toilets of the "jiggle the handle" crowd. Pretty easy homeowner fix.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Plumbing issue
Wayne67vert #1366695 Sat Jun 27 2020 05:59 PM
Exactly it's saved my bacon a few times for that very problem, open flapper. "Designed to fix no/slow refilling, running, and noisy toilets"
Re: Plumbing issue
Wayne67vert #1366696 Sat Jun 27 2020 06:02 PM
ODSS Lawman
I agree. Fix the toilet, new flow master, flapper, done. $30 in parts.
Now as for the septic, I would suggest an alarm system that alerts you well before the tank reaches overflow. It’s a simple float system that can be wired to a light, alarm, or even a system that can email you.
SWEET
Sergeant At Arms
Old Dominion Stovebolt Society
BUNS?!?!?! Where we're going, we don't need no buns.....
1950 GMC 450 (25% owner)
1951 Chevy 1/2-Ton
The GreenMachine
In the Stovebolt Gallery [stovebolt.com]
Re: Plumbing issue
Wayne67vert #1366717 Sat Jun 27 2020 08:55 PM
Yep, it's right to replace the innards. Kinda light the battery in my car, when it stutters, I replace it. Usually last about 5 years. The toilet is at least 8 years old.
However I'm also thinking about other possibilities for water leaks and wood floors, cabinets, drywall etc.
For what my insurance deductible is, I could put the safety backup in my house. It would also possibly cause a reduction in my homeowners insurance.
The septic overflowed from the toilet not shutting the water off.
Wayne
Re: Plumbing issue
Wayne67vert #1366725 Sat Jun 27 2020 10:23 PM
It seems to me you need to have your septic tank pumped. Around here they are 500 to 1000 gallons.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Page 1 of 2 1 2
Moderated by  Bouncer, Justhorsenround
